I recently bought two ESC's, one here a Hobbywing and a Turnigy T-180. Both are V3 and both are cutting out at full throttle at the end of a straightaway. I have programmed the LVC from low to no protection and same results. Running a 1515-1Y in a DF 33 with an M445 on 4S. Different batteries 1P or 2P make no difference. Tried Castle and NEU motors same results. Used Hitec, Futaba and Flysky radios no change.
When it cuts the power if I blip the throttle it comes right back on to full for a short time then cuts out again. If I hold at about 90% they both work. Am I triggering a high current cutoff? Ran an MGM 280 with data logging and and I pull 140-180 amps peak. On 6S with a 1521/1900 kv it cuts out less but still does it. 150-160 amps on 6S. My older V1's work fine but the new ones seem to have a very sensitive amperage cutoff. Have run both with and without BEC, no change. Transmitters at 120% can that be a problem.
Mic
Mic
