Strut for a catamaran ?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all considering building a catamaran .Do i use flat bottom hydro strut or round bottom mono strut ? The hull will be 29'' in length i have a Speedmaster .21 hydro flat bottom strut sitting on the shelf. Would that work? Regards Andris Golts.
  • jwohlt
    • Nov 2015
    • 41
    If you have it why buy another? Sure it will work ok.
    • slider46
      • Mar 2016
      • 75
      I have run a few cats over the years mostly gas power, and if you are going to run any high speeds you will want a skegged strut to stop the prop walk....
      • Mxkid261
        • Jun 2015
        • 734
        I run a round bottom in a 32" fightercat and it works great does 70-75mph on 6s. No skeg on the strut and no prop walk but it doesnt turn very well more of a straight line boat. Using a m445. Im sure the flat bottom will work though. I thought flat bottoms were for more transom lift like on hydro and riggers but I could be wrong
        • modvp55
          • Mar 2015
          • 131
          I have a Cheetah running 6S and a modified X452, it has a flat bottom strut that works just fine. It will also turn at WOT.
          • slider46
            • Mar 2016
            • 75
            looks like you're back to square one. enjoy..
            • ray schrauwen
              • 9475
              Start with what you have and if you have any issues you can go to a Speedmaster skeg strut at a later date. Since they are both the same manufacturer its an easy swap out to this: http://www.offshoreelectrics.com/pro...os-spds-017-SK
              Nortavlag Bulc
