Installing the water jacket
  • JohnZ
    • May 2010
    • 254
    Ok, so I got a different water jacket for the TP Power motor from OSE and before I make a mistake with installation I need some recomendations on what kind of lubricant to use to slide it on with. I am aware that some oils can damage certain rubber compounds and have no wish to make that mistake.
    Light machine oil, Crisco, a good quality olive oil?
  • Mxkid261
    • Jun 2015
    • 734
    I rub a small bit of marine grease on the o-rings and that always seems to work well.
    • grsboats
      • Jul 2012
      • 975
      You are correct about some oils damaging silicone o-rings...I use silicone grease for years.
      GO FAST AND TURN RIGHT !
      www.grsboats.com.br
      • Doby
        KANADA RULES!
        • 7280
        Dish soap.
        Grand River Marine Modellers
        • tlandauer
          • 5666
          I use silicone oil from my days building shocks for RC cars.
          • jim82
            • Jan 2013
            • 1358
            I've never had a problem with 3-in-1 oil.
            • JohnZ
              • May 2010
              • 254
              Thanks.
              BTW I found the TP Power water jacket to fussy to deal with so I bought one from OSE and it looks like it will slide on without having to fuss around trying to get the O rings seated.
              cheers
              • jwohlt
                • Nov 2015
                • 41
                And, if you plan to leave it on and do not want and chance of leaks then a small ring of silicone around it and the motor works well...Just what I do....easy to cut off with a razor.
                • JohnZ
                  • May 2010
                  • 254
                  Sounds like a good idea. Thanks. I've got some Permatex black silicone adhesive/sealant that should fit the bill.
                  cheers.
