Mystery Claud 200a 2-6 cell
  • lonford
    • Jul 2016
    • 4
    Hi
    Mi esc mystery claud 200a lost his memory and i'm trying to reprogram this
    with 3 type of radio and the motor wan't turn
    the boat turn over and water went in, i manage to blow and dry the esc and he work the next day.
    suddenly he stop and making a sound of 10 beeps.
    now i'm busy programming he make all the beeps and tones to select and save but the motor is not turning
    Program
    Cell selection: 1-1/1x3 for 6 cell (22.2v) and cut off (18v)
    Throthle : 1-2/2x1 for Auto Throttle Range
    : 1-2/2x2 for 1.1ms to 1.8 ms
    : 1-2/2x3 for hard acceleration
    Brake : 1-3/3x1 No Brake
    Direction : 1-4/4x2 Counter clock wise
    Timing : 1-5/5x1 1ยบ - For 2-4 Pole Inrunner Motors
    Pulse Width Modulation(PWM) Setting ??? :what is this for??
    :1-6/6x1 for 8Khz
    Do i miss and thing?
    The motor just click fwrd and back but want turn
  • ray schrauwen
    • 9475
    This is a Suppo esc. If you hook everything up and the esc gets hot and motor not moving then esc is most likely dead. These are very cheap ESCs.
    Nortavlag Bulc
    • ray schrauwen
      • 9475
      If you remove red radio wire and use separate radio battery, it may work but most likely dead.
      Nortavlag Bulc
      • lonford
        • Jul 2016
        • 4
        Hi,
        Yes they are cheap and was my first ESC to try out.
        The ESC go's in all programs and selections programs by the beeps and sound. i toke the UBEC off the cable and work with battery pack
        i install a little Fan on top to keep him cool while i'm trying to program it.
        So if you connect the batteries without turning the motor the ESC should stay cool?
        if he should stay cold then Huston We Have A Problem !
        • ray schrauwen
          • 9475
          The esc should not get hot while programming. Either the esc is bad or the motor may also be bad.
          I would suggest getting a new esc.
          Nortavlag Bulc
          • lonford
            • Jul 2016
            • 4
            Hi
            thanks for your help .
            I hope is not the motor, the motor is a brand new motor and been monitoring both for temperature.
            I drove the boat 3 times and never more then 15minutes.
            Maybe a month old, i think i got this by end of june and use 3 times.
            i have order a Sowrdfish 220a, i have to wait and see now .
            Thanks Rayn
            • ray schrauwen
              • 9475
              If you give more information about the boat and everything in it, you will get more help.
              Make a stand for you esc so it doesn't sit where water can get it easy.
              Nortavlag Bulc
              • lonford
                • Jul 2016
                • 4
                Hi,
                Yes my ESC is higher then the motor
                but due to the boat turn upside down and water went in the boat.
