Titan 40 with twin proboat outboards
  • centralrcmystic
    • May 2015
    • 245
    6 pounds on the hurricane but we're going to lighten it. I have turned one of the drive shafts around soo I guess that is a right spin now it looked ok. I'm going to try the hurricane 44 that's what model boating is all about, maybe it will be badass maybe not but the build will be fun. I'm not trying to break speed records juts have a cool decent running boat.
      • 8012
      Set up with 10S2P they weigh in close to 20 lbs. 6S2P would shave off a couple pounds, but still a big, heavy boat with a lot of wetted surface. They normally run a large-format motor like a 2028, big Neu or big Lehner, and 60mm or larger props.
      Oh boy, another YouTube expert.......
      • photohoward1
        • 1610
        Had one with a NEU 2230 with an ABC 2614/3 chopper. 68mph all day long. 12s way over 70.
        • centralrcmystic
          • May 2015
          • 245
          I had a 58 fountain tp5670 on 12s2p 65mph all day. That is not the goal on this boat however. I just hope to have a some what fast boat that has outboards for the cool factor. I'll probably just run 6s on each motor 5000mah I won't have that long of run time but I don't mind changing the bats out .
          • properchopper
            • 6968
            Fun Times in Arizona
            • centralrcmystic
              • May 2015
              • 245
              Well got a new hurricane on the way. soo it's ok to extend the motor leads to get the ESC's away from the rear. How long are we talking 3-4 inches ??
              • 785boats
                Wet Track Racing
                • Nov 2008
                • 3169
                Turning the shaft around will not give you a reversed wind cable. It is still wound the same way. You will need to get a reverse wound flex if you want to run contra rotating props.
                • centralrcmystic
                  • May 2015
                  • 245
                  #23
                  Know where to get one with square ends on both sides that fit the proboat outboard
                  • centralrcmystic
                    • May 2015
                    • 245
                    #24
                    Originally posted by Doby
                    So they are running in opposite directions...did you get one flex cable with the opposite windings?
                    I don't think anyone makes one
                    • centralrcmystic
                      • May 2015
                      • 245
                      #25
                      What would the down side to running both counter clock
                      • Hotrods
                        • Sep 2010
                        • 281
                        #26
                        Only down side would be turning to the left.
                          • 8012
                          #27
                          The steerable drives should counteract most/all of the left-turning degradation and counter the potential for increased prop walk.
                          • centralrcmystic
                            • May 2015
                            • 245
                            #28
                            Think I will play it safe and just spin both counter clock. Don't feel like snapping drive cables everytime I run
                            • axel
                              • May 2007
                              • 127
                              #29
                              check the length of the proboat cable - if its about the same as the K&B you can get a reverse from Hydro& Marine
                              • centralrcmystic
                                • May 2015
                                • 245
                                #30
                                Thank you I found on funrcboats.com 15 bucks each though ouch
