P-Limited vs P OPC Tunnel
  • cjs
    • 322
    Looking in the NAMBA rulebook, the only difference I can tell is that Limited has to be from the list of approved motors. Is this correct? Also, browsing through the 2015 FE Nationals results, it looks like the top 3 in both classes all ran a UL1 motor, so is there actually a difference between the setups for the 2 different classes?
    Thanks,
    Chris
  • Darin Jordan
    • 8335
    Thanks,
    Chris
    There really aren't many people around the country racing OPC Tunnel, and even fewer racing in P-OPC. Most race in P-LTD, hence the lack of results/info for the class.
    However, I can definitively tell you that the setups had BETTER be different... :)
    For heat racing, I would expect a competitive P-OPC to be one of the larger 30-32" sized OPC tunnels (typical 7.5cc sized Nitro hull), and powered by an appropriate 2200-ish KV 36 or 40 x 74mm+ sized motor.
    Darin E. Jordan - Renton, WA
    • cjs
      • 322
      Thanks for the input Darin. Along with P-Limited, is there a specific ESC that has to be used? Or is that only within IMPBA or club rules?
      • Darin Jordan
        • 8335
        No. P-OPC, at least in NAMBA (and I'm pretty sure IMPBA), is wide open. P-LTD for NAMBA is as well, except the actual motor, of course.
        One COULD race their P-LTD OPC in P-OPC, and probably be reasonably successful, especially if you can finish heats.
        • properchopper
          rcgoatbuild@snotmail.com
          • 6968
          Video speaks for itself
            • 9488
            Thanks,
            Chris
            Chris, I don't remember how many we had racing that day, but everyone ran the UL-1 motor
            • cjs
              • 322
              Does anyone have links or a good phrase to search to browse P-Limited setups? I can't seem to find what I am looking for using the search.
              Thanks,
              Chris
              • Darin Jordan
                • 8335
                Thanks,
                Chris
                Chris,
                What specifically are you looking to find out? PM me with questions if you like. I can probably point you in the right direction, based on experience, not just what I've read...
                • Darin Jordan
                  • 8335
                  Chris,
                  OOps... I see you already have. Responded...
