What motor is in this 24" hydro??
  • oxide80
    • Jul 2009
    • 10
    Ok so i took a chance and bought a boat on ebay that had little description, it ended up being an older Bandit Hull, shovel nose hydro 24-25" long hull. I haven't messed much with boats and just wanted something to mess with on the pond other than my old JS 800.
    Anyways it appears to be a club racer, 12c sub C pack, castle creation ecs but no idea which one no labels on it (ice lite maybe) and a silver brushless motor. Just trying to get an idea of rpm, and batteries it should use.
    Any info will be helpful.
    Pete
  • TRUCKPULL
    • 2975
    It looks like it mite be an AVEOX.
    Larry
    • oxide80
      • Jul 2009
      • 10
      It is an older Aveox motor with the endbell screwed into place, but no idea of Kv rating. Any suggestions for a starting point or ecs size? The castle barracuda doesnt power up or connect to my castle link, im assuming it's in meed of repair.
      • TRUCKPULL
        • 2975
        Is it a CC-80 or a CC-125
        Can you post a picture of it?
        Larry
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 979
          We use to run those boats with the aveox motors on 8 nicads. That's going to be a 3s lipo nowadays. If that one was set up for 12 nicads then you want to use a 4s lipo.
          Mark
          • oxide80
            • Jul 2009
            • 10
            I figured lipo 4s was fine, just 0.4v difference. Ecs doesn't connect via castle link, I will try a battery see if it powers up to program, if not I will contact castle regarding ecs repair. As for Aveox motors, whats the voltage limit on them? How fast did they go? I've always run castle products in my 4 wheeled vehicles, mambas, and sidewinder I'm familiar with
            • oxide80
              • Jul 2009
              • 10
              Larry, here is a picture of the ECS, I have an email pending with CC tech support regarding the issue connecting to the Castle Link. I don't know if it's software issue or the controler yet. I found programming directions on CC's website, I'm going to try that tomorrow and see what happens.
              • TRUCKPULL
                • 2975
                Pete
                That is one of the older CC-80's it has the old style spider fet's and the large radio board.
                I run nothing but CC -ESC's in all my boats, I have 9 of them right now.
                I modify them for water cooling also.
                If yours is only in need of a new radio board, I can replace it and add water cooling for you.
                An 80 upgraded with water cooling becomes a CC- 120.
                Larry
                • oxide80
                  • Jul 2009
                  • 10
                  Larry, Thanks for the information. I was able to connect the ecs to an old Skyion radio I had kicking around and I have forward and reverse on 2c lipo. But still no connection using the Castle Link. I'm going to run through the yes/no manual programming and see how it responds. If no success I will shoot you a message about upgrading / repairing this one
                  Thanks alot!!
                  Pete
