Stepped Sponsons on Hydros and Angle of Attack?
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    Just trying to understand something.
    This diagram is highly exaggerated, but it seems the faster you go, the further back the boat would ride, thereby decreasing the angle of attack at higher speeds. The higher angle of attack at low/mid speed would make it easier to plane....essentially the same concept as a recovery pad.
    Is this what stepped sponsons of this nature/direction are used for?
  • Hotrods
    • Sep 2010
    • 281
    If I was building a hydro/rigger a good place to start is 7 degrees on the AOA. I am not really sure how to answer your question though.
    • grsboats
      • Jul 2012
      • 975
      My riggers work pretty well with 4 to 5 degrees AOA.
      GO FAST AND TURN RIGHT !
      www.grsboats.com.br
      • JimClark
        • 5907
        our 1/10th scale hydros are I think 5 degrees
        Billy Graham
        • TRUCKPULL
          • 2969
          Pete
          Take a look at my album on the build of your hull.
          That is what has worked best for me when racing.
          Now if you want to try SAW runs - it may be a lot different.
          Larry
          • Shooter
            Team Mojo
            • Jun 2009
            • 2558
            Are you guys talking about the recovery pad AOA? Those numbers seem high for a ride pad or bottom. I think the Pearl ride pads are at 2-3deg.
            Anyways, what I was trying to figure out was the purpose of the steps. Seems the boat would ride further and further back as it planes out. If you have steps, you are essentially dropping the nose further down and thereby changing the bottom AOA as it rides further back.
