I'll second the recoil 26 rtr from proboat, comes with everything, batteries and all for the first timer. Self righting, spare batteries are inexpensive since it's only one 3s pack, and it's easily accessible at local hobby shops. My second suggestion would be to look into a Cajon commander, this is an airboat by aquacraft. It would work well for sweeping the shoreline, especially if there is grass. The down fall would be that it's not self righting, air prop could be considered more dangerous to some people, and it has a slightly higher overall price point compared the recoil 26.
For yourself, the Zelos does not dissapoint. Stock it will run 4 min flat out with a 6s2p configuration and no heat issues. Because of the flat pads it does drift a bit around the corners more then a boat with ride pads that have some deadrise/dihedral angle so if that bothers you its something to consider. That is not to say it doesn't turn though, I was entering corners at 50+ mph with no issues. As mentioned the layup is SOLID. The only bad part is its so much fun to drive you may find yourself ignoring priorities just to go to the lake and run it.
