Hi guys,
I am sure there is a millions postings about how to fix torque roll, that is one of the reason I decided to make a new thread about it. I don't want to try a bunch of things and if it is not working, then I need to make it back to the original setup.
I know it is part of the "Beauty of the boating", but I am just try to avoid any unnecessary things do to. I thought a wise advise could always come in handy before any further invest.
I just put together 36" Genesis, everything custom. Test run shows big torque roll issue, (boat lean to right). Before I invest an extra 90$ for factory balanced props, I would like to get some advise, what would be the best thing to shorting out first.
Here is my setup.
Twin- TP-4060 1700kv on 6s-5000mah, Octura x442 prop on the right side and x442r on the left side. Sharpened and balanced by me, I think I did a good job with that, I will post a video. left side prop turns clockwise and ride side one turns counter clockwise. Boat bitz 130mm small-offset Rudder with dual pickup.
The battery sitting on the middle, the weight is pretty much balanced out in the boat. The bottom of the rudder is 2,1/4 inch lower then the bottom of the blade, It is adjustable.
Low profile strut 110mm long, also adjustable up and down.
The only thing I tried to do, I put a single washer between the strut attachment and the transom on the right side on the right side on the attached screw, so the strut kind a leaning to the left, but did not worked. I torque roll issue still remain.
I would do a video, but the water is to choppy today.
I know that ,here is a lots of Genesis owner, I hope some of you won't mind to give me some ideas, since I am kind a new in boating , this is the part when I definitely need some good advise.
Thank you guys!
here is the link for the balanced props. Please tell me if is not good.
Here is my setup.
Thank you guys!
