Water Jacket help
  • Raydee
    • May 2007
    • 1603
    Water Jacket help
    Guys does anyone know if the Neu 1515 and 1521 water jackets have a different internal diameter? I bought a 1515 jacket to fit on my 1521 and I can't get it on the motor. I have installed many of these jackets in the past without a problem.
    Team Liquid Dash
  • Eyekandyboats
    • 1921
    yeh they change.. and they wont fit so dont bother LOL
    Neu i find uses a miss match of everything to get there motors together..... they use i guess what come first. I have some motors with 540 bolt patterns and some with out. some have bolted cases and some dont. some have flat spots on the shaft, and some dont.
    its pretty vierd
    EYEKANDYGRAPHICS
    www.rclipos.com
    • Stealth Assassin
      • 610
      Whoop It! Nah just kidding... Did you put the calipers on It?
      D
      • Raydee
        • May 2007
        • 1603
        I took the orings off the jacket and the jacket fits over the motor without a problem BUT with the orings in it is imposible to get the jacket on. I am at a loss right now, The boat is ready to go in the water tomorrow and I have no water cooling. I may take a trip to the local hardware store and see if they have thinner orings. The only other thing I can do it find someone that will machine the groove a little deeper but I don't I will find someone willing to do that.
        Team Liquid Dash
        • Eyekandyboats
          • 1921
          run it with a small prop and don't bother cooling.
          EYEKANDYGRAPHICS
          www.rclipos.com
          • AntronX
            • Jul 2008
            • 333
            Dumb question, but did you put machine oil on the motor can?
            • Raydee
              • May 2007
              • 1603
              I tried oil, and every other substance I had laying around. I never had a jacket that didn't fit, some were tight but they all went on.
              Team Liquid Dash
              • HRC
                • Jan 2008
                • 328
                Ray, the 1515 jacket will not fit the 1521. The 1521 has a larger diameter. Even though Neu spec. give the same diameter they are not. When I first started making them for Steve we found this to be the case. FYI: the 1512 and 1515 are the same diameter and the 1521 and 1527 are the same diameter. Hope this helps.
                Dave
                • Stealth Assassin
                  • 610
                  Old o-rings?
                  • Raydee
                    • May 2007
                    • 1603
                    Thanks for the reply Dave. I did some research and saw that too. Dave I am going to send you a PM.
                    Team Liquid Dash
                    • j.m.
                      • Jul 2008
                      • 838
                      I hope you didn't try wd-40. With some o-rings this can actually increase their diameter.
                      (i use this technique to seal bolts better in the chambers of paintball guns)
                      • detox
                        • Jun 2008
                        • 2318
                        Rubbing alcohal works verygood plus it evaporates.
                        • kwiktsi
                          • Sep 2008
                          • 578
                          This may help over come the slight diameter difference :D
                          My favorite search engine http://google.com
                          • Jeff Wohlt
                            • Jan 2008
                            • 2716
                            Windex
                            www.rcraceboat.com
                            jwohlt5362@yahoo.com
