Ul-1 power for 32'' wildthing ?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all as i posted in a previous thread i fried the esc motor +lipo in this mono i still have a new ul-1 2030 kv motor and a Seaking 120 amp esc the mono hull is 32'' long and hull +hardware+radio gear weights 60 oz. would the ul-1 system work on this hull ? Regards Andris Golts.
  • ray schrauwen
    • 9472
    Better off with 1800kv Aquacraft motor. The 2030 will not turn a very big prop on a boat that heavy. Any idea what the hull only weight was??
    If you are going to use what are considered stock motors, you only need one 4S, 5000Mah - 5800Mah pack to run it or a pair of 2S packs in series. A pair of 4S packs 4000-5000mah is too heavy for this motor. I have a nice Juicy outrunner, about 1970kv that would push that boat nicely. I'll lend it to you but, run 4S2P with it. I can even lend you a water cooling plate depending on your motor mount. The motor is this one: http://www.hobbyking.com/hobbyking/s...ass_Heli_.html
    Shoot! They are on sale!, darn it! Mine is the black Fightercat version but, same motor.
    Nortavlag Bulc
    • Andris Golts
      • Jan 2011
      • 504
      Hi Ray thank you for the great information when i get the floatation foam removed and all the mess wiped out of the hull i may give this a try. Regards Andris.
      • ray schrauwen
        • 9472
        Let me loan you the motor and coupler. see if it works for you. I could pack it to the Can AM.
        Nortavlag Bulc
