I picked up some 6mm red ose connectors with the nylon housing. Soldered the bullets to the wires like normal. But when it came time to insert the bullets into the nylon sleeve.....what a chore! I have successfully put two sets on after a pretty good struggle. Anyone else having issues with these?
Ose 6mm red connectors
Tags: None
I use a small punch and tap it with a screwdriver handle or the palm of my hand. They have to fit tight because you don't want them coming out.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was -
Try not to make such a mess of solder all over the outside of the bullet and they should go in easy.
At least my 8mm were that way
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Are they supposed to be difficult to put together and pull apart? I feel like I need a pliers just to disconnect them from the batteries....Comment
The 8mm ones aren't. They work awesome.
I dunno maybe the 6mm are different
I kept the solder where it's supposed to be lol. I've decided that I will just use the bullets and in place of the casings some shrink wrap. Less hassle. Thanks for the help thoComment
That sucks dude. Kinda defeats the purpose of getting the polarized connectors
I decided to give them another shot I think I was putting the bullets in the wrong holes. Previously I had the male connectors in the small side, I will try the female connectors in the small side this time.Comment
As far as I know, the male does go in the small side.
Pull in from front
I picked up some 6mm red ose connectors with the nylon housing. Soldered the bullets to the wires like normal. But when it came time to insert the bullets into the nylon sleeve.....what a chore! I have successfully put two sets on after a pretty good struggle. Anyone else having issues with these?Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33Comment
I installed a series connection in my spartan, used female side in smaller hold, male in bigger. Punch them in with a flathead screwdriver. Working great so far, just a little tough to disconnect from batteries but that's no big deal.Comment
