Pursuit trim tab setting?
  • tlandauer
    • 5666
    #31
    Originally posted by boilo56
    Do you think i can go bigger on prop? my temps today on 5s were: motor 85.9F, ESC: 89.3F, batts: 103.4F & 105.2F.
    Temp is certainly low, but I don't know much about the stock motor's ability to handle bigger props. When you get a 40mm motor, you can go to 45mm if not a 447.
    Originally posted by Turbo Dan-O
    Just got back from running mine again. I have it set it up the way Peter A showed above. I am running two 2s batteries though. 27% COG. Are you using a straight edge to check it? I "eyeballed" mine at first and it was running dry and porpoising(hopping). I put a straight edge on it and yup, I was off a bit. Runs perfect now!
    Very nice! I like the "saddle" set up. I like the heatsink in silver!
    • boilo56
      • Aug 2014
      • 390
      #32
      I tought about this setup, but i wanted a more secure way to hold the batts. Those little silver screws frighten me alot in case of a big crash.
      • boilo56
        • Aug 2014
        • 390
        #33
        Tlandauer, i'll wait until my props gets in and will do more runs to see what will happenned. And i will also try the same setup with the stock metal prop i have. i will post a vid of the run tonight in this tread.
        And for the 40mm can, is there some waterjacket for a T8 1550kv from Tekin?
        • tlandauer
          • 5666
          #34
          Sounds good, hope I wasn't talking too much, seems you know exactly what you are doing.
          Happy Boating my friend!
          • boilo56
            • Aug 2014
            • 390
            #35
            On the contrary, Tlandauer, i'm really not sure where i am going, i ran the boat around 6 or 7 times... It my First Real boat... the rio ep got me hooked up!!! I am trully following what you guys say almost to the letter! I'm a french canadian noob that do what you said, cause YOU, at OSE forum ARE THE BEST SUPPORT in the RCboat world!
            • boilo56
              • Aug 2014
              • 390
              #36
              My order came in yesterday, so i have a 42x55 grimracer and an Octura x442 under hand! i will try the X442 first, the Grimracer prop sleeve it too long for the driveshaft, so i will cut it down to the right size. I aslo received a respond from the Tekin forum about the RX8 Gen2/ 1550vk combo that i want to try in the boat. I asked about the burst ampsof the RX8, and the person answered:'
              Postby TekinTeamMgr ยป Wed May 06, 2015 1:03 pm
              You won't need burst amps in a boat.
              Is it true??? I see references to the burst amps on this forum very often... Does burst amps really matter in a boat setup?
              • boilo56
                • Aug 2014
                • 390
                #37
                Hi again! I went to run the boat and try some prop swap. I went first with 4s,grimracer 42x55 prop, and recorded a speed of 32.3 mph. Second run i did was on the octura x442, the speed was slower: 29.8 mph. I didn't tri the x442 on 5s, but i did try the grimracer, for a speed of 38.5 mph, but i almost lost the boat on that run... A waterline poped out of the ESC and filled the boat! Lucky me, having my reveiver monted on the top front of if allowed me to save it.
                Here is the 5s run:https://youtu.be/rcVumssihZY
