Carbon fiber epoxy?
  • klbo
    • Aug 2014
    • 104
    Carbon fiber epoxy?
    I'm trying to epoxy two pieces of carbon fiber together I scuffed up both sides mixed up a batch of epoxy and the two pieces chipped right apart there was no bond i'm using zap Epoxy it's Z proxy finishing resin looks like I might have to buy some new epoxy I thought this would bond to the carbon fiber
    I know jb quick and jb weld bonds really well. It needs to be scuffed with very coarse sandpaper.
    • klbo
      • Aug 2014
      • 104
      I'm going to need to Epoxy my carbon fiber motor mounts if this Epoxy doesn't stick to these two plates not gonna work well for my mounts either
        • 8012
        Finishing resin is....for making a finish, not great at bonding. JB is very good, parts need to be free of any oil or grease and roughed up a bit though. What type of carbon fiber? For what purpose are you gluing the parts together?
        • klbo
          • Aug 2014
          • 104
          I was doubling up two 2.5 MM carbon fiber plates for a stuffing tube support support and I also have to glass in carbon fiber to carbon fiber motor mounts
          • tlandauer
            • 5666
            As said, Finishing Epoxy ( PT-40) is for finishing, meaning that it is much easier to sand than the PT-39 ( 30 min. epoxy). It cures with a more brittle quality than its counter part. However, it should not chip right apart like that. How long has it been on the shelf? I never use that for structural bond but on occasion I have used the PT-40 MIXED with milled fiber glass with no problems whatsoever. I just made a rudder bracket extender out of CG plate, 2.5mm, just to give you an idea, I sand with 80 grit sand paper and when I rub the areas where I plan to glue, the friction is very noticeable.
            Just my $.02
            • klbo
              • Aug 2014
              • 104
              It was pt 40 but the mixing cup hardend very brittle time for new epoxy?
              • tlandauer
                • 5666
                Well, the little amount on the inner wall of the cup is always brittle, especially for the PT-40. Yes, your results will be better with PT-39.
                Sand and clean with acetone before applying the epoxy. I also clean the mixing cup with acetone and the mixing stick. JB weld is great but it doesn't flow well, so I use different epoxy depending on the application and location.
                Sent from my D6708 using Tapatalk
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  JB Weld works for me very well on any material boat relating...
                  Canada
                    I use jb weld on everything that I do not want to ever come undone. It has not let me down yet. I've had hard flips at 90+ and it held. I use other epoxies for the esc covers and stuff I may change later.
                    • jcald2000
                      • May 2008
                      • 774
                      Please don't use acetone it is EXTREMELY bad for your body, White Vinegar from the grocery store at $2.00 a gallon works great to remove uncured epoxy!
                      • capnswanny
                        • Feb 2012
                        • 817
                        Here's an excerpt from the West System (my favorite) Users Guide:
                        "Clean Bonding surfaces must be free of any contaminants such as grease, oil, wax or mold release. Clean contaminated surfaces with lacquer thinner, acetone or other appropriate solvent."http://www.westsystem.com/ss/surface-preparation/
                        This is NOT a toy?!?
                        • jcald2000
                          • May 2008
                          • 774
                          Now look up it's effects on your body.
                          • steinersamuel
                            • Nov 2008
                            • 405
                            Nitrile gloves people
                            • klbo
                              • Aug 2014
                              • 104
                              Yes definitely nitrile gloves even when you are sanding carbon fiber definitely don't want to get any of that On you and yes all my parts were clean it even popped off the wood really easy bought some west systems 105 epoxy the 207 Clear Hardner
