FE experts Needed
  • grayhamby
    • Mar 2014
    • 38
    FE experts Needed
    Hey guys- I'm building a 1/5 scale SwitzerCraft Baby Bullet as seen on the 152vo website. I'm planning to use an aquacraft 60 amp esc , 4s electrlx 5200 battery, on a modified lawless lower unit. The utility class of racers has a maximum yardstick value of 1,370,00 which is motor Kv (2030) x volts (14.8) x diameter of prop in mm x pitch (slope) . I'm wondering if another motor is indicated, 3s pack, and what props to try? I'm running the set up with a ABC 42-55 b&P on a LeeCraft 3.5 Tunnel hull I converted to FE recently and am getting 47 mph. I'm not sure what the slope of a 42-55 is. Any help woul be appreciated. The kit is amazing as to quality of wood, directions etc. Thanks G Ray HambyIMG_7341.jpg
  • Doby
    KANADA RULES!
    • 7277
    If you are planning on running 3S, the AQ ESC will not work.
    Grand River Marine Modellers
    • flraptor07
      • Aug 2013
      • 2451
      how long is this boat? 1/5 scale?
      • properchopper
        rcgoatbuild@snotmail.com
        • 6953
        25.79"
        Pitch = 55mm / 2.165 inch
        • photohoward1
          • 1608
          I'm assuming he is talking about pitch?
          • grayhamby
            • Mar 2014
            • 38
            The SC BB works out to 655 mm x 268 mm. or 25.787 in.lenght by 10.551 in. wide to answer flraptor07. Thanks properchopper. GRH
            • grayhamby
              • Mar 2014
              • 38
              Why not? doby I'm new to FE. GRH
              • Doby
                KANADA RULES!
                • 7277
                That controller has a LVC that is set for a 4S pack....on a 3S pack it will think the pack is dead (basically the LVC will think the 3S pack is a really low voltage 4S pack and turn itself off)
                • grayhamby
                  • Mar 2014
                  • 38
                  Thanks--What aq esc or other would be good for my application? GRH
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1136
                    George, I've had really good results running these. http://www.offshoreelectrics.com/pro...eaking-120a-v3 ...they are well made esc's and we have seriously abused them with no probs... DJ
                    • grayhamby
                      • Mar 2014
                      • 38
                      Thanks for your reply. I'll try the OSE esc. GRH
