Hey guys- I'm building a 1/5 scale SwitzerCraft Baby Bullet as seen on the 152vo website. I'm planning to use an aquacraft 60 amp esc , 4s electrlx 5200 battery, on a modified lawless lower unit. The utility class of racers has a maximum yardstick value of 1,370,00 which is motor Kv (2030) x volts (14.8) x diameter of prop in mm x pitch (slope) . I'm wondering if another motor is indicated, 3s pack, and what props to try? I'm running the set up with a ABC 42-55 b&P on a LeeCraft 3.5 Tunnel hull I converted to FE recently and am getting 47 mph. I'm not sure what the slope of a 42-55 is. Any help woul be appreciated. The kit is amazing as to quality of wood, directions etc. Thanks G Ray HambyIMG_7341.jpg
FE experts Needed
If you are planning on running 3S, the AQ ESC will not work.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellers -
25.79"
Pitch = 55mm / 2.165 inch2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
That controller has a LVC that is set for a 4S pack....on a 3S pack it will think the pack is dead (basically the LVC will think the 3S pack is a really low voltage 4S pack and turn itself off)Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
George, I've had really good results running these. http://www.offshoreelectrics.com/pro...eaking-120a-v3 ...they are well made esc's and we have seriously abused them with no probs... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
