Picked this boat up off of ebay. From pics it look just like a 32" rivercat. I just got it here delivered just now and what I do not like is it has a plastic prop and the outdrive is loose and has lots of play even after tightening it down. The boat has a 1515 2200kv NUE motor and I am buying a 180 seaking speed control once there in stock. What prop should I get and from where? Do I need another drive as this one is not tight? If so what? I dont like the steering servo rod, idk maybe it will work ok? I like the aluminum battery trays. In my blackjack 29 I just velcro them, prob work ok for this too? Thanks for any help I appreciate it.
My new EBAY boat
1) prather 215 prop to start out with. Then maybe a 220 if temps stay in check.
2) if the drive has slack, you can replace the bushing. Take clear close up pics of it.
3) maybe the batts would stay in place with just velcro but I doubt it. A low speeds it might be ok. Maybe velcro and Pool noodles.
4) steering rod should be fine as long as it does have much slack.
This is probably my favorite hull, I have 5 of them at the moment, so I do know a little bit about them. That motor will be fine on 4s (think I told you that) but you can run it on 5s or even 6s just to make a speed run. Do not cruise around on 5s or 6s tho. It will get hot. I'd stick with props in the 40mm to 43mm range.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was -
Thanks kfxguy! I didn't know they take bushings. Do you know what size the flex shaft is? And is there on pre-made?Attached FilesComment
I'm pretty sure the flex would be .187 (3/16) buy could be 4mm. You'd have to measure. Looks like the 4mm strut in the pic. I don't think they come pre-made unless that's a tfl rtr boat.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I like the velcro straps with a buckle that are sold here, however, I also use velcro strips that you can buy at the big box stores. Would also seriously consider adding support for the rear of your motor, this
boat should get you around 50mph, and is gonna be slappin some waves.Comment
You'll also want to kill the "Y" in the cooling line. Water takes the path of least resistance so odds are one side of the "Y" won't get as much water as the other. You can either run the motor and ESC cooling lines in series or parallel depending on which way hides the lines the best.Comment
BOPMPBC Open Mono, Open Electric Champion.Comment
Good catch. I thought I saw that earlier but I was quite bust at work and couldn't give all my attention to it. Looks like the strut has been changed because of the different color it is. He could get some washers to tighten it up or get the offer rudder bracket they sell.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Just so you know, the rivercat is not a well turning boat like the cheetah is. I have both. I actually have three of my own rivercats. Lol.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Big problem I have now is my new seaking 180a speed controller does not fit once the hatch is closed. I might try taking the aluminum plate off but its epoxied down and once it is removed I am still not sure it will fit. What do you guys think? Maybe try returning the speed controller for another or remove plate?Attached FilesComment
