Aeromarine Shadow Setups
    To avoid jacking/cluttering another thread I've opened this one to answer questions about the hydro.
    Originally posted by montymike
    My batteries are on the Tunnel where where do you fit a single 6s or 8s?
    I use either two 3S or two 4S packs up front. I cut out the bulkhead to allow more room, and maintained hull strength by gluing/glassing a piece of 3/16" plywood across the top of the stringers. This gives me a LOT of room to move the packs for CG adjustment, and lets me strap them down between the rails for those 80+ mph crashes. I'll have better photos later.
  • montymike
    • Jul 2012
    • 774
    Ok thanks would love to see what u did thanks mike
      Here is a shot of my oval racer along with shots of my SAW version with the modifications to the hull, allowing the packs to fit and move fore and aft as required. NOte that the forward bulkhead is intact in the oval boat, but cut away in the SAW boat.
      • montymike
        • Jul 2012
        • 774
        Nice thanks for showing me mike
        • montymike
          • Jul 2012
          • 774
          What would be a safe bigger prop with my setup?
          4092/1390 leo, sordfish220pro, has a x447 on it now do need to add
          A cap bank thanks mike.
            You could probably run an x547 or x450 safely for a bit more speed. Do you "need" caps? Depends on how long your power wires are and the quality of your cells. IMO most of the commercial cap banks are inadequate for high-amp setups particularly 1P setups. But they are usually better than nothing. They do reduce stress on the ESC and that is always a good thing.
            • montymike
              • Jul 2012
              • 774
              Ya power wire is only 3.25 inches long. On the sordfish. Thanks mike
              • dasboata
                • Dec 2010
                • 3152
                Wow very nice Jay they were great sp40 boats,, I expect good speed out of it keep us posted !
