Haha yeah I saw that video , cringed a bit
Genesis build failing
Use those water inlets from OSE, one for each transom http://www.offshoreelectrics.com/pro...prod=ose-80405 and a propeller 1,4 pitch 2 or 3 blades 45mm diameter
IMG_20140726_225430.jpgI was gonna buy those but I can't wait , too excited !! So I just moved the tubes I had into the bottom and cut it flush. Just waiting for the epoxy to dry. Hopefully out with it tomorow .Comment
Most prefer offset rudders with high performance boats, single or twin. This gets the rudder out of the prop wash, which is full of air and reduces rudder efficiency in holding the transom in place. The aerated water also can cause the boat to "hunt" with poor directional stability. Plus it is easier to remove the driveline than when a rudder directly behind the prop is used. I have set a lot of SAW records with cats featuring offset rudders. All my oval racing cats have offset rudders.
Many use the rudder directly behind the prop with success, but IMO it is not optimal. ProBoat seems to agree, they modified their RTR cats from direct rudder to offset rudder about a year after they were introduced.
Sorry to jump in, I had experienced the "hunting" on both Cat and mono when the rudder is inline. I thought it was a weak servo, this makes a lot of sense now. I never could understand why my MG will go left and right as if it is stricken with "Parkinson's disease"
The moment that I installed the off set rudder, this problem was gone. Although the wah-wah-wah had increased a lot until I blue printed the sponson ride pads.Too many boats, not enough time...Comment
