Genesis build failing
    You need about an x447, tongue removed, thinned. Get rid of those water pick ups like said earlier. Adjust it to where it rides light but doesn't flip out the water. That's a 70 plus mph setup
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1136
      #32
      Originally posted by Juraj
      [ATTACH=CONFIG]118439[/ATTACH]Yeah the only 2 blade prop I have that's even close is a 42mm but that's pretty small , I figure since this motor is 100mm long it should have plenty of torque, I have just cut off the skeg and adjusted the strut and I'm gonna go out and see if its faster without it .
      I'll do a GPS speed after every modification and then I will know what made the most difference. Why doesn't this boat like a 3 blade ?
      Is it just more lift?
      A 642 is a 42mm prop...
      • Juraj
        • Jun 2014
        • 31
        #33
        Why is that?
        • Alexgar
          • Aug 2009
          • 3534
          #34
          x646 or m545 would work well if you have them
          • devo
            • Aug 2012
            • 146
            #35
            This may sound like a dumb question but are you sure you have the end points adjusted right on your radio? Running a prop that big with the batteries you have should be darn near melting or getting your connectors and electronics very warm if not hot. Im not sure your actually getting WOT.
              When you get it right it should see 70mph easily
              • 785boats
                Wet Track Racing
                • Nov 2008
                • 3169
                #37
                I'm inclined to agree with that Devo. It's the first thing I thought of when I read the first few posts. Not a dumb question at all.
                Juraj.
                Did you programme the "Throttle Range" on the ESC as per Step#2 in the instructions. This should be done after you set all the parameters for Cell Count, LVC, Timing, etc.
                What settings have you programmed into the ESC?
                The motor kv is pretty high for a prop that big & that pitch on 6s. As Devo & others have pointed out. Especially such small packs & only a 1P set up.
                • Juraj
                  • Jun 2014
                  • 31
                  #38
                  I honestly haven't done the calibration and yes its quite possible I'm not running wot but the biggest issue right now is the fact that the chine walk is so serious that I actually can't even wot. It turns too much . how can I fix that?
                  Right now I have the hull pretty empty , I'm doing all the cooling changes so I'll do the physical changes now and do the calibtlrations when its back in the water.
                  • devo
                    • Aug 2012
                    • 146
                    #39
                    I have my rudder adjusted to one side some instead of perfectly straight, so that my boat tracks straight when im really getting on it. I'm sure there are other ways of dealing with the issue, in example propping down or at least dropping the pitch, but the prop your running is probably your main issue. Try a 2 blade 445 s&b and see what happens
                    • Juraj
                      • Jun 2014
                      • 31
                      #40
                      Yeah I have adjusted the rudder too but its still overpowering it at close to full throttle . I'll get a new prop and see
                      Thanks
                      • martin
                        • 2887
                        #41
                        The Genesis being a quite narrow hull gets out off shape easy with to much prop.
                        • Juraj
                          • Jun 2014
                          • 31
                          #42
                          The hull deforms?
                          • tlandauer
                            • 5666
                            #43
                            The hull deforms?
                            No, he meant the hull will not handle well, I have not heard of any deform issues with that hull...
                            • martin
                              • 2887
                              #44
                              Yes torque roll affects the Genesis where its narrow.
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #45
                                It only DEFORMS when you hit a turttle @ 71mph! https://www.youtube.com/watch?v=YEcF...4Q-xrOOtP2C-8w
