30c grim racer 4s packs vs 65c DINOUGY packs.
  • Rumdog
    • 6453
    #31
    Have you yet to realize your goal is unattainable?
    Create a new, possible goal, then inquire for help.
    "I'm a professional"
    • Doby
      KANADA RULES!
      • 7280
      #32
      [/COLOR]
      Please don't use my name when you're posting stuff like that
      And a (slight) reality check : Here's what 78.xx mph looks like on the oval - and you want to come up with a stable FE Cat to finish mill + six laps on the race course at 80+mph ?
      (no lipos were harmed in the making of these videos)
      https://www.youtube.com/watch?v=jC6I_ad8Isw
      Nice vids Tony, but as you know, they don't even come close to race water conditions that the OP wants to run in. Throw a few more boats on the water at the same time and then we will see the "real" race speeds are.
      Grand River Marine Modellers
      • Peter A
        • Sep 2012
        • 1488
        #33
        Hi Rude5150
        I know you want some quick answers to how to make your boat go fast, and how fast. The only way to acheive what you are after is spend time on the water testing. That way all the things that you will learn about your boat, speed and handling with different motors, batts and props, will leave you much the wiser and smarter. And better at driving your boat.
        If you think that racing oval at 80mph would be easy, just go and try it at 50-60, it will be a big challenge with lots to learn when 5 other boats are trying to beat you to the next corner. If there is one thing I have seen many times is that the fastest boats often dnf, and the slower better set up boats win. Just my 0.02.
        • flraptor07
          • Aug 2013
          • 2451
          #34
          A little advise, giving rude5150 advise on FE boats is like giving advise to your dog on the dangers of drinking from the toilet.
          • Doug Smock
            Moderator
            • 5272
            #35
            That was helpful.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • rude5150
              • Feb 2014
              • 339
              #36
              What about me using tp 4050 1730kv to get there?
              • properchopper
                rcgoatbuild@snotmail.com
                • 6968
                #37
                Here's a race with a few more IC boats on the water
                Here's a race with FE P-Sport hydros doing around 60-65mph. The OP's theorectical 80+ mph Zonda wouldn't make it through the first turn on its bottom
                • tlandauer
                  • 5666
                  #38
                  Originally posted by rude5150
                  I will buy them. I just wanted to ask the offshore member, who been there and done that before. I thought u guys could give me an idea.
                  I am just being honest, i am no racer, but i happened to use those two brands of batteries not long ago in my rigger under almost identical water, wind, temp condition wit the same motor,prop and ESC. With the Dinogy 65c, 5000mah, 4s, my speed was 69.6 mph, thanks to many kind people who gave me sound advices on tuning and set ups. The Grim pack gave me 68mph, you may laugh at me with these speeds, but it was a goal for me to get close to 70 mph, and however slowly i get there, every step was a reasonable progress and effort.
                  Like i said, Dinogy is my choice, but Grim pack is great too, but I do not believe these two different brands will give you a 10 mph difference.
                  My suggestion for you to buy them and try is not poking fun at you.
                  Last but not least, we seem to be on different channels all the time, people are trying to help, but you get ahead of yourself and it becomes difficult for people to follow you.
                  • rude5150
                    • Feb 2014
                    • 339
                    #39
                    This is suppose be a web site to get information, not to get insulted with smart comments. I thought I was dealing with professionals. I appreciate the few people who try to help me out.
                    • rude5150
                      • Feb 2014
                      • 339
                      #40
                      Im on 60mph on 4s 30c grim racer packs with 447 prop . I wanted faster.kfxguy mentioned going with the 1730kv to get faster.I asked about using the 4517 pitched prop with no positive feedback. Am I on the right path to 80mph using the TP4050 1730KV motor with 4517 pitched props?
                      • rude5150
                        • Feb 2014
                        • 339
                        #41
                        As for lipo batteries. I figure the higher c rating lipo is better for me doing higher speeds and I have both brands too but not in 4s. I came here cause I thought that it would be wiser to ask u guys about speed improvement. It was either get the higher c rating battery to see how much more speed I could get or just change motors for more performance speeds.
                        Now can u guys tell me if kfxguy idea is better with going with the 1730kv motor for more speed?
                          Lower kv is going to give you more torque. Torque that is needed to make the props cut through the water. Then your adding more voltage (6s on those motors) so that will give you the rpm you need and the extra torque will help to get the props cutting through the water at a higher rpm. Higher rpm on the same prop will make you go faster (putting it simple). You need to read my mini rivercat thread where I swap motors and go to a lower kv (1800kv vs originally 2650kv with the exact same motors) and you'll clearly see and understand what I'm telling you.
                          As for batteries, you not going to see a huge increase in speed unless the batteries your using are toast or just not up to the task of what amps you need. I plan on doing some back to back battery testing this weekend. 5000mah 50c 3s venom vs 6500 65c 3s spc to see if I pick up anything. I suspect maybe 1 mph if that.
                          • rude5150
                            • Feb 2014
                            • 339
                            #43
                            • rude5150
                              • Feb 2014
                              • 339
                              #44
                              Thank you for the explanation this is what I have been looking for since I have started this thread
                              • rude5150
                                • Feb 2014
                                • 339
                                #45
                                Thank you Kfxguy.
