here is some photos i have taken..... not the greatest of pics but hopefully they tell a story of any issues. As mentioned before temps were warm to the touch, not hot after a few wot passes. I dont have any data logging on that particular esc (none that i know of anyway)
Frustrated
- IMPBA Hall of Fame -
- IMPBA Hydro Technical Director -Comment
Those water pickups can go up quite a bit. Lots of unnecessary drag there, good for a few mph and a better handling boat.Comment
THe motor mount needs serious support. The first flip will have that motor mount torn off the bottom of the hull. Even a motor that size with rear support (which you do not have) from factory will tear out because of the weight and lower quality epoxy used from factory.Nortavlag Bulc
If you keep the brass dead straight a couple inches up from the stut you'll be fine, let the bend further up handle the minor strut movements.- IMPBA Hall of Fame -
What the others above said. In addition:
-With the boat flat on the table set the strut flat and 1/8" above the tabletop as a start.
-CG @ 9.5" ahead of the sponson transoms to start, not the rear of the boat.
-You shouldn't need the skeg on the strut - extra drag.
-True up the ride pads with 220 grit on a sanding block, then smooth with 400 grit.
-Rudder water pickups are far better than the draggy pickups on the boat now, if you keep them raise them up so the top of the bevel cut is even with the sponson bottoms.
ing in the hatchComment
In regards to battery placement, doesn't the centre of the batteries get placed at the point of balance of the hull, which is called cog? And in this case point of balance is around 33% which puts the front of the battery pretty much in line with the front lip of the hatch opening. Please correct me if I'm wrong as I'm fairly new to fe boats, just want to clear a few things up so I don't doubt and double guess my adjustments. All the expert help is much appreciated.Comment
20140610_232331.jpgComment
frustrated
.Comment
I have removed the old stuffing tube and bent another. I'm lucky not to have lost the prop in the lake as the flex cable was holding on by a couple of threads, hence speed issues due to bind… ( have another on order). The guy who owns a fe store here in oz, sold and advised me the skeg provided extra stability on turns and never warned me about those water pick ups… little disappointed in that! (Would you recommend getting rid of the skeg?)Anyway will try a couple of different setups as posted and advised by the fantastic folk here on ose, and see what works best for the cat and eventually get rid of those water pickups..… what's better rudder or flush mount? Will keep you posted on how things go. Again thanks to all who have contributed in giving their advice and opinions!!, keep it coming throughComment
