One or the other, Ul-1 2030 kv running 4s 5000mah or Castle 1515 1y running 4s2p 8000mah with a T-180.
From my other hydro I pretty much know what to expect with the spec 2030.
What could I expect in terms of speed AND handling for running ovals with the 1515 setup?
I have both power setups, haven't installed the motor mount or stuffing tube. Speedmaster hardware on the back.
Waiting until I decide what setup to mount the motor so I can set the CG.
Will be a .150 cable for the UL-1 or 3/16 if I go with the 1515.
Those are the only two options I have on the bench at the moment so I'm not interested in Leopard or TP suggestions. Nothing against those motors I'm simply using what I already have on hand.
Thanks & Cheers
Thanks & Cheers
