Whiplash 20 power questions
  • siberianhusky
    • Dec 2009
    • 2184
    One or the other, Ul-1 2030 kv running 4s 5000mah or Castle 1515 1y running 4s2p 8000mah with a T-180.
    From my other hydro I pretty much know what to expect with the spec 2030.
    What could I expect in terms of speed AND handling for running ovals with the 1515 setup?
    I have both power setups, haven't installed the motor mount or stuffing tube. Speedmaster hardware on the back.
    Waiting until I decide what setup to mount the motor so I can set the CG.
    Will be a .150 cable for the UL-1 or 3/16 if I go with the 1515.
    Those are the only two options I have on the bench at the moment so I'm not interested in Leopard or TP suggestions. Nothing against those motors I'm simply using what I already have on hand.
    Thanks & Cheers
  • kevinpratt823
    • Aug 2012
    • 1360
    I have a Neu 1515/1Y in mine, 4s2p 5000 and a H-7 gets me 63mph reliably, but I wish I went for 8000mah, it's kind of heavy, especially in turns. I topped that setup out at 71.7mph with an aggressive prop last season for short runs. Threw a 5s/5000 in yesterday just to see, and I got 70.5mph.
    My private off road rc track
    • ray schrauwen
      • 9438
      If it's a light build you can use the 2030 Ul-1 motor but, You can't prop much more that a 442 or 642. I'd use the 1515 you don't have to worry about heat as much
      • jfrancisco892
        • Feb 2012
        • 546
        I have a whip 20 and have run it in p limited sport hydro and p sport hydro trim. It seems slow and boring with a 2030 after running it with the 1515. Go big or go home!
        • Shooter
          Team Mojo
          • Jun 2009
          • 2520
          There you go. 'Mr. Hot Rod' has spoken.
          • siberianhusky
            • Dec 2009
            • 2184
            Yep, think it's going to be the 1515, be my first P hydro. Already have another P-spec boat to beat up on the UL-1's.
            I do have one other guy I can run it against, maybe some of the other guys will build P boats when the see the speed.
            Thanks for the info.
            Cheers!
