3s boats?
  • Doozie870
    • 828
    3s boats?
    Has anyone had any success running 3s? it looks to be a popular voltage with planes and helis. packs and esc's are abundant and cheap!
  • Avanti
    • Nov 2007
    • 1280
    a lot of micros run 3s that is what I used in my hydromite and that is what minicat racing recommends for their boats
    check out DrJet's threads he is big into micros
    • ED66677
      • 1300
      my 29" run 3S (two 2600mAh in //) with a 8XL no very fast but still impressive!
      Emmanuel
      • Jeepers
        • May 2007
        • 1973
        James do you remember this boat when you came for the BBQ? its the blue one in the first pic with yellow lettering, this was a 3s boat its set up was a 8L on 2 11.1v 3000 mah wired in parallel, hacker master navy 99 esc and a y536 prop this thing blistered the water!
        • Jeepers
          • May 2007
          • 1973
          a 7XL or 6XL on 3s would run good!
          • Steven Vaccaro
            • 8723
            I'm testing a Asian 3s mono boat this weekend. So far its fast, but I cant keep the outrunner temps down. I now have a smaller prop to test out to see what that does.
            • Darin Jordan
              • 8335
              I ran at the 2007 Nationals with 3S in P-Offshore... I was using a smaller hull (26"), so in order to not overpower it too much, I ran 3S with a Neu 1515 1.5D (2700KV)... Ran great!
              I would actually prefer 3S over 2S... It's easier on cells and there are more motors in this KV range...
              Darin E. Jordan - Renton, WA
              • ED66677
                • 1300
                yes 25-26" would be better than my 29" under 3S!
                Emmanuel
                • Doozie870
                  • 828
                  Darin what would the approx under load rpm be with that set up.
                  • Darin Jordan
                    • 8335
                    Well... a 3S pack is 12.6V fully charged... and is 11.1 nominal... So, using 2700KV, I would figure the setup to be 34,000 max, likely more around 32,000 assuming a drop to 4V/cell under load... Nominal would give about 30,000 RPM...
                    Keep in mind, I was using this for an Offshore setup... and using 3S2P... Didn't even come close to stressing the system...
                    • ED66677
                      • 1300
                      look at this and this
                      I know it's not incredibly fast but... it's a 2.5Kg 29" long with a 8XL and 3S2P (2x2600mAh in //) spinning a K40,5 at 60+Amp so there's room for speed again IMO!
                      sorry for the video quality I have problems to upload
                      Emmanuel
                      • Doozie870
                        • 828
                        Looking good
                        Im going to try 3s in an electrovee.
