my leopard 4082 1600kv has red flash on rotor and some smoke coming out end bell. is it toast?
smoke
Yeah some oil can make smoke I think. I'm pretty sure it's happened to me before.
I never oil my motors anymore and never have an issue
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
uhhh.... i don't believe soThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
The motor has failed.
If the stator looked ok the failure probably occurred where the wires enter the can, it happens.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
How hot was the motor when you saw smoke? More important is to look at the lacquer on the copper winding, if ther are discolored or seems to have "melted", then it's gone. When lacquer is being cooked it can have some smoke and a burnt smell. How are the three wires coming out of the motor? i.e., condition of the insulation.
Oil could give smoke, but on a BL motor you should never see spark.Too many boats, not enough time...Comment
smoke
Oil could give smoke, but on a BL motor you should never see spark.Comment
I'm running a fightercat daytona 37" cat with a hobbywing 180 on 6-s. after toasting this 4082, I have 4 choices 1.) buy a new 4082 1600 kv 2.) use a 4082 2000kv i have on 6-s 3.) run the 4082 2000kv on 4 or 5 -s. 4.) buy a T.P. 4050 (seems to be a direct bolt-in )
by the way, would running this boat on 4 or 5-s give decent speed and longer run times than 6-s ?Comment
brake cleaner entire motor. reassembled and test ran. by the way, motor never got hot. when tested after cleaning , no sparking, but small amount of smoke coming out endbell. guess i need to buy new motor. does T.P. make a direct replacement for the leopard 4082 1600 kv? same bolt patterns and size. ?
I recently toasted a brand new Aqua Craft 1800kv motor. I put it in my Miss Geico and after the first minute or so, I brought her back just to check temp, I saw smoke when I opened the lid, also smelled burnt odor but I thought it was the bearing oil which I put a bit too much. Second time out it died within 100ft. Motor was burned , it was the wires entering the endbell that somehow shorted. The boat had run Proboat's 1800kv motor without any problem. I replaced with a Leopard 4074/2000kv which I had for a while, so far real happy. Sorry...drifting...as usual...
These bolt patterns are all the same. I would not go beyond 5s on your 2000kv motor. I run a Leopard 4082/2000kv on 4s2p and it's plenty fast, good run time.Too many boats, not enough time...Comment
Did you first see smoke after applying brake cleaner? I ask because I am curious for my own knowledge. I wonder if the chemical weakened the lacquer.
These bolt patterns are all the same. I would not go beyond 5s on your 2000kv motor. I run a Leopard 4082/2000kv on 4s2p and it's plenty fast, good run time.Comment
I've been running Tp motors for some months in riggers and they really run great..... give atry to one for the same money! GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
by the way, would running this boat on 4 or 5-s give decent speed and longer run times than 6-s ?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
