Talked to Phil this evening, Seems as if he is building up a new 45" Hydro hull for the gasser guys, and can be electric powered as well. Also found out that the next project he is hoping to release, is basically a stretched Stealth thats going to be 36". Figured I'd share up! Went ahead and got an SS45 in cf on order!
Phil Thomas New Hull.
Talked to Phil this evening, Seems as if he is building up a new 45" Hydro hull for the gasser guys, and can be electric powered as well. Also found out that the next project he is hoping to release, is basically a stretched Stealth thats going to be 36". Figured I'd share up! Went ahead and got an SS45 in cf on order!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
LMT
LehnerMotorenTechnik.comComment
I hope Phil addresses the lateral support for FE. We're carrying so much more weight than nitro. If you don't bulkhead the trailing edge of the sponsons all the way across they'll rip themselves apart. I had to do that on the whip. First one ripped in half.Noisy personComment
Sounds like I need to get the FE cowling plug done for the GSX480 gas sport hydro!
IDK man. You still gotta get around the ML and the Whip. Both pretty solid performers in that class.
I hope Phil addresses the lateral support for FE. We're carrying so much more weight than nitro. If you don't bulkhead the trailing edge of the sponsons all the way across they'll rip themselves apart. I had to do that on the whip. First one ripped in half.Nortavlag Bulc
I've got one of the prototype boats for that Stealth 36 and if the production boat is anything like the one I have it's gonna be pretty badass. I'm still working the bugs out of mine but it's looking pretty good. Here's the last time out, it's still pretty loose !https://www.youtube.com/watch?v=_hLm...ature=youtu.be
You should bring that boat up to Michigan for the Nationals.Comment
If Phil found a way the tie the right side sponson to the tub where we like to mount our motors to it would be bullet proof. Basically the weight of the motor hangs from the fin itself instead of relying on the layup to hold it all together. We're hurling so much weight into the turns with FE boats. Ever do the math? Yikes. Multiple G's. Suddenly that 15 pound boat weighs a bunch. Structure is our friend.
My 2 cents at least.Noisy personComment
Thanks for the quick reply. I'm fine then because I aint running a 2230 like you did, do...Nortavlag Bulc
