I am new to boating I have a stock impulse 31 I wanted to know if I could run one 5s battery instead of two 2s batteries , I have one water line to run to the engine and one to run through the esc if that helps. Any info would be helpfull thank you.
one or two batteries
Tags: None
Running 5s ~18v will raise the voltage from your 4s ~14v set up. It all depends on your electronics (ESC and motor kv)Q: Do you know the difference between Men and Boys...?
A: The price of their toys. -
Welcome to OSE
If you have the Revolt v2 (version 2), your running the pro-boat 3630 (1800kv) motor & the 80A 6s compatible ESC (electronic speed control).
I am assuming there are 2 battery plugs because the recommended cells are 2 8.4v NiMH packs, 2 2s lipos in series, or 2 3s lipos for 6s power. Myself personally I would stick with 2 2s packs for 4s power just to be safe. If I were going to run 6s in a stock revolt, I would feel more comfortable upgrading the ESC to a Turnigy 180A marine ESC first.
Now if that is the 80A ESC, you can run 5s using 2 batteries like we do on our Aquacraft UL-1's. Get a 2s & a 3s battery, but make sure the ratings are identical on both packs ie: 5000mah 35c 2s & a 5000mah 35c 3s for 5s power in series...
If you run pairs of packs wheather its 2 2s or a 2s & a 3s that don't match, odds are you'll have a fire. FYI ....
