Is this over kill ?
  • fastisgood
    • Apr 2010
    • 126
    Is this over kill ?
    50" princess cc2028 mgm 400/63 esc on 10s trying to do about 50mph
  • Fella1340
    • May 2013
    • 1025
    Looks good, great components. Other than trying to drive the boat at anything else than full throttle for extended periods of time. The esc will heat up fast trying to run at slower speeds. You have a full blown race setup there. what kv are you running. Unless you have a relatively low kv motor I see this boat attempting to much faster then the hull can handle. How much a concern I will leave to the experts. Have you run the boat? What kv, voltage and prop size do you plan on running? This information will be key determining what will happen. Someone should be along to help. Good news is if you want to build another boat to go insanely fast your a good ways there. The experts should be able to tell you how to tune things to your goals or otherwise...
    • Savage Skidoo
      • May 2011
      • 312
      i'm putting one of them cc2028 in my sprint cat build , looking good .
      www.facebook.com/Boaters and Crawlers Durham
      Durham Off Road Rc Club - www.dorc.ca founding member
        • 8750
        Yea I think itll do at least 50......
        • twissted
          • Jul 2012
          • 867
          good looking hull should be fun to use. Is it durable?
          • lenny
            • Sep 2010
            • 4296
            Hear a build. http://forums.offshoreelectrics.com/...-Princess-boat
            ? ONLY IF THEY WORK
            • lenny
              • Sep 2010
              • 4296
              One more.
              ? ONLY IF THEY WORK
              • Rumdog
                • 6453
                Yes.
                  • 7990
                  If all you want is 50 mph you might be better served with 8S rather than 10S. That motor runs very well on 8S swinging a larger, more efficient prop for that large hull. The problem is the top speed you want, as mentioned that 10S is really a race setup with that motor and you may have to 'prop down' quite a bit - sometimes tough to do with props available and still maintain efficiency with that large hull. 8S does not mean slow, a club member runs that motor on 8S in his T-Sport Hydro and hits 74 mph in oval trim.
                  All that said it will work well on 10S with the right prop. An x455 would be a place to start.
                  • fastisgood
                    • Apr 2010
                    • 126
                    Ok I will start with that Thx guys for all the help
                    • iridebikes247
                      • Dec 2011
                      • 1499
                      Even running 6s2p for the the maiden might be a good idea? That hull is sick can you give me a link to it? I'd love to do a similar build.
