electronic options for atomic arc hull 58in
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Originally posted by Alex Hogue
    Tp4060 with a 130 and stock prop should get me to stock levels or slightly higher correct?
    How do you figure say stock out runner transfer to x size in runner ? Ig its the motors options and sizing that the most confusing at this point
    Hard to compare an outrunner to in runner by size. The make/build quality/efficiency can be so vast between manufacturers. So much of this is just your best educated guess, and learning from what other people have tried and their results.
    • forescott
      • 2686
      I guess I just don't see the point of spending an extra $100 for the hv130 over the proven t-180. Pushing that setup over 6s would likely fail anyway.
      • lenny
        • Sep 2010
        • 4294
        Found one,
        I am sure there are better one.
        Page #3 of the thread I posted for you with all the info may give more light on outrunners.
        ? ONLY IF THEY WORK
        • forescott
          • 2686
          Nice work Lenny! That is one strange coupler. Not too sure about soldering or gluing the flex cable to the sleeve, but if its done correctly it sure would be a nice solid connection between the motor and flex. No more grub screws digging into and distorting the flex cable.
          • lenny
            • Sep 2010
            • 4294
            Yes I have buddy that love's the HV 130/180A on 6s in his miss Geico,
            And some other boat setups he is using them in.
            Said it lets everything run nice and cool on 6s in the Geico.
            http://forums.offshoreelectrics.com/...%E2%80%8EGeico
            I have a buddy the only runs sport running and he really likes the HW 130/180. He uses it in an AC 36" cat, and a 41" mono with 5692 1100Kv TP Power & similar Leopards on 8S 2P budget Zippy cells.
            ? ONLY IF THEY WORK
            • Alex Hogue
              • Feb 2014
              • 7
              ok so for motor options there is the tp motor or leopard
              tp 4060 in 1130kv
              leopard 4092 in 1050
              both motors are the same size can as the het 700 98, given the tp is a little above stock im thinking it will be the tp motor with a t180
              http://www.offshoreelectrics.com/pro...er-seaking-180
              http://www.offshoreelectrics.com/pro...p-4060&cat=181
              http://www.offshoreelectrics.com/pro...prod=ose-83005
              should be all i need and a servo from the lhs and should have me under $800 for a boat thats ready to go and runs cooler then the rtr setup
              • forescott
                • 2686
                Sounds good! Keep us updated on the progress!
                • capnswanny
                  • Feb 2012
                  • 817
                  Hey guys, what about the Turnigy T20?
                  http://hobbyking.com/hobbyking/store...arehouse_.html
                  Looks like a Proteus copy from Hobbyking, was considering it for a 45" mono...might be an option for this?
                  This is NOT a toy?!?
