high amp. data logger?
  • wolf IV
    • May 2008
    • 961
    I see this is a widely discussed topic on many rc forums with home remedies involving shunts and multi meters. But my question is is there anyway to modify a watts meter already on the market ? Or even someone willing to make me two recorded high amp loggers for me? With all the high amp r's especially boats I'm shocked that there isn't any 200-300 amp rated loggers out there. Help
    http://www.youtube.com/watch?v=e-npTLBHefY
  • siberianhusky
    • Dec 2009
    • 2187
    Very easy to modify an Eagletree to measure up to 300 amps. I haven't done it but a buddy of mine has
    Not positive of the details but I do know he found the info for the mods online, maybe even on here.
    Pretty sure if memory serves you just install a shunt across the positive and negative leads of the logger. I know no dis-assembly(sp?) was required and it only took a few minutes. I think the recalibration might have taken him longer than the actual modification.
    Been a couple of years since Ken did this and his ET was still working fine at the end of last season.
    He might have posted about it, user name is Kendt. Do a search and you may find his postings.
    • jcald2000
      • May 2008
      • 774
      I posted it years ago here. I have recorded as high as 325 amps and it still works.
      http://forums.offshoreelectrics.com/...-in-15-minutes
      • wolf IV
        • May 2008
        • 961
        • wolf IV
          • May 2008
          • 961
          • wolf IV
            • May 2008
            • 961
            Man I read this over and over and didn't get it until i blew up the picture of the ET got ti!! great thank you!
            • ray schrauwen
              • 9475
              This is on sale at R2 hobbies, it's a plug in extra device for an Eagle tree unit: 300amp Expander
              Nortavlag Bulc
              • oscarel
                • Dec 2009
                • 2128
                That one works with the data recorders, not the inline eloggers.
                • KillerDave
                  • 370
                  Thanks for running this thread AGAIN guys...
                  I have just ordered two set-ups for my HPR and will be making the same mod...
                  On the accuracy note... Surly... if you measure the IR of the logger and match that with the shunt, you'll get a more accurate reading?
                  I have an electrical engineer friend that will work on it with me so I will report back....
                  HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
                  • Pheyd
                    • Sep 2014
                    • 79
                    If the input resistance across the logger is the same as the shunt, then you will get exactly 1/2 of the current going through the logger. However, I doubt that'll be the case, a shunt will always have less resistance. Hence the need to calibrate in order to offset the difference for the logger.
                    Source: I am an Electrical Engineer :)
                    • CornelP
                      • May 2009
                      • 745
                      If you do not care much about recording rpm, this is a very good and accurate option:
                      • KillerDave
                        • 370
                        https://astecmodels.co.uk/catalog/pr...5038a7011160dd
                        Thanks CornelP but for me, I'm already into the ET e-logger... I've made the mod to both units but I am struggling to put a good load on to do the calibration....
                        I have seen folks using strings of lights but I'm not sure that's a very accurate method????
                        I do have some kit at work that I can load them with but doing "home jobs" is prohibited! :-/
                        I'll see where I get.....
