Need help with my HPR setup
  • larryrose11
    • Jun 2010
    • 757
    Gorgeous boat, by the way.
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      The 4 blades only for show I believe. You might be fine with 42-47 mm 2 blades
      • TheShaddix
        • Sep 2013
        • 759
        Does anyone know how to program these esc's ? How do you connect them to pc using that usb cable? Need some special software?
        • RaceMechaniX
          • Sep 2007
          • 2828
          Where in CA are you?
          BTW, those are not Schulze esc's so the instructions I made for Schulzes are not applicable.
          TG
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • TheShaddix
            • Sep 2013
            • 759
            Oh, I didn't realize that. I'm in Vista, North of SD. Do you know how to set up the esc that I have? I just need to set them up for 6s instead of 5s that the boat previously had.
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              Have you got the USB or serial connector? If so I can tell you to program and email you the software
              • TheShaddix
                • Sep 2013
                • 759
                I have the usb cable. I downloaded ProgPC but it's all in German which is of no help! Do you have the english version?
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  no english version, but if you take a screen shoot and post it here I can write the settings for you
                  • TheShaddix
                    • Sep 2013
                    • 759
                    • TheShaddix
                      • Sep 2013
                      • 759
                      When I plug the cable in nothing happens in this software. Is that normal?
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        You need the main battery to the ESC's then hit lesen that will read the data stored if nothing happens you may have to change the comm port on top of the screen timing to auto as these do a good job. Under zellen is where you set the cell count. If you leave on auto it will derect the amount if cells you hook up by the amount of beeps corresponding with the cell count
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          #27
                          Akkutyp is battery type so set to lipo. All features under that field relates to the battery itself, you might be able to work it out once you hit the drop down menu. On the left bremse is brake you can set to on Or off. Sorry I'm all over the place I'm out at the moment in my cell phone and don't have those ESC's any longer
                          • TheShaddix
                            • Sep 2013
                            • 759
                            #28
                            When I hit lesen it just says "der regler wurde nicht gefunden". Like it doesn't recognize that the esc is plugged in. I plugged my lipo in like you said.
                            • TheShaddix
                              • Sep 2013
                              • 759
                              #29
                              Nevermind, I relaunched the app, it changed Com-port to COM4 and now i can set it up!
                              • TheShaddix
                                • Sep 2013
                                • 759
                                #30
                                One thing I don't get is the polpaare which is poles, how many do i set that to? 2 or more?
