Nimh to Lipo
  • Lakefrontlivin
    • 176
    Nimh to Lipo
    Need help figuring out what to run for a lipo setup in my Drifter cat. It's 34" long and has a 10XL motor, Warrior ESC, Turbo transmission and currently running 2- 9 cell 3300Mah packs in series.
    What would be the equilolent in lipo packs?
    Is there such a thing as overkill with the lipos ? I mean if I put 2-4900Mah lipo packs in series would it hurt anything?
    Thanx in advance,
    Tom H.
  • lonewolf
    • Jul 2007
    • 658
    for starters each lipo cell is 3.7 volts from there add it up. 2s=7.4 3s - 11.1, 4s =14.8 ect. That would be running in series. for more milliamps run in paralelle(spellcheck) The common set up equivelent to 12 cells is 4s in voltage. a common set up is 4s 2p hope this helps... Dave
    Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
    • H2OCamel
      FAST ELECTRIC EVERYTHING
      • Oct 2007
      • 484
      Tom if you are running 2X9 cells in series that is just shy of 22volts so you would go with a 5s setup which is 18.5 volts or 6s which is 22.2volts.
      "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
      • Lakefrontlivin
        • 176
        Thanx Guys..
        This is what I have for Lipos:
        2S1P 4900 25C (I have two packs) 7.4v each
        4S1P 4900 25C (I have two packs)14.8v each
        4S1P 5000 20c/30c/50c (I have two packs)14.8v each
        Which should I run?
        Thanx, Tom H.
        • Steven Vaccaro
          • 8723
          I would start testing with the (2) 2s packs.
          • Lakefrontlivin
            • 176
            In Series as the Nimh ones were?
            Thanx, Tom
