What is a good stuff for stuffing tube
  • agentorange
    • May 2013
    • 238
    Ok so on my Genesis cat the stuffing tube was leaking and found out it was loose at the hull. I removed the stuffing tube and cleaned the old sealant off the bottom of the hull and inside the hull. I just don't know what to use I have JB weld and some 3M fiberglass resin. So my question is what do I use and do I just put it on the inside or on the inside and outside. Please help.
  • rickwess
    • Apr 2013
    • 777
    I'll preface this by saying I'm not an expert.
    You want to use a slower curing epoxy (30 minutes) make sure you get the epoxy inside the hole as well as the inside of the hull. Having build-up on the outside won't support the tube very much and it just looks bad too. When it's cured, you can add a little more on the inside to build it up.
    Mixing in and additive like milled fiberglass to the epoxy would be even better.
    • lenny
      • Sep 2010
      • 4294
      Hear a link to what you want.
      http://forums.offshoreelectrics.com/...is-works-great
      ? ONLY IF THEY WORK
      • agentorange
        • May 2013
        • 238
        Thanks alot guys for the information. Lenny bro that link is great I am going to do that.
        • siberianhusky
          • Dec 2009
          • 2187
          JB works great for stuffing tubes, I also use it for motor mounts etc. Never had anything break loose using it.
          • Southwest
            • Sep 2012
            • 274
            I use 5 minute mix but make sure the 2 parts are equal in amount. Now if you don't make parts equal, it will stay soft for good. Also heat up epoxy so it is warm and will flow into small pin holes and etc.
            • jcald2000
              • May 2008
              • 774
              I have tried them all, JB weld is the winner!
