Ponton angle ("deadrise") on Hot Shot 24" tunnel hull
  • Erik Aa
    • Aug 2011
    • 80
    Hi all.
    I'm building a 24" Hot Shot for electric conversion.
    I have a question regarding the angle on the pontons (the "deadrise").
    Is this angle too steep on the stock Hot Shot? Should I make the pontons with less "deadrise"?
    I am aiming for a fast turning hull.
    Thanks,
    Erik.
    What is the stock sponson deadrise? There are a lot of OPC builders here but they may not be familiar with the old flat nosed HotShot. What power system will you be using?
    • Erik Aa
      • Aug 2011
      • 80
      I'll measure the sponson deadrise tonight.
      Planned powersystem: OS lower unit, Leopard 3674 1400 kv, Etti 150 opto esc, 6 S, x440 or x442.
      • siberianhusky
        • Dec 2009
        • 2187
        I've had both the old square nose and the Sprint, IMO you will have problems with that much power in these hulls, an Aquacraft UL-1 setup is plenty of power to push these designs beyond any stable hull speed.
        Currently running a VS-1 with the UL-1 motor, much better hull design and longer but still wouldn't want any more power. A buddy of mine is attempting a TS-3 on 6s, so far the results are not what I'd be happy with. Sure goes like stink in a straight line, if it stays on the water.....
        He did a beautiful conversion on it, if it were mine I'd be dialing the power back. To each his own. He is more into the top speed thing, I like turning laps. If he gets it dialed in it will fly.
        • Erik Aa
          • Aug 2011
          • 80
          Thanks for your input.
          I am building this hull, and I might go for a less powerful setup. I have not tried a tunnel before, so I don't know much yet.
          However, I also want to build a 6S low kv tunnel hull that *turns really well*. I am interested in accelleration and turning ability primarily.
          Do you guys have any suggestions for appropriate hulls?
          Thanks,
          Erik.
          • er8sr
            • Apr 2013
            • 183
            Iam currently running a Vs-1hull O.S Lower seaking 120 amp esc 440 prop Align 500mx 1600 kv outrunner on 6s gps it @49 mph and runs fir a solid 5minutes no temp issues..
            • mgcrimson
              • Oct 2010
              • 49
              Check out ML Boatworks. You wont be disappointed! I have the PS295 which is an earlier version of the new PX300.
              http://www.mlboatworksrc.com/.
              ROLL TIDE ROLL!
              ML Boatworks PS295, Dumas Hot Shot Sprint 3.5, JAE 21FE, Yellow Jacket Outrigger,
