Propulsion system recommendations for large deep vee (55")
  • fox88gt
    • Jul 2013
    • 103
    Hi everyone,
    I recently purchased an old school Dumas kit of the Wellcraft Scarab 38 KV (the Miami Vice boat). Was wondering what you all might recommend for power in this big girl? This boat will be a scale cruiser/wave pounder so top speed isn't the priority - run time, reliability, and fun are the goals. I'd like to keep the price point similar to (or cheaper) than the 2-stroke alternative. I love gas 2-strokes but would like to go electric on this one if I can keep it affordable.
    As a reference, I looked at an Atomik 58 Cat at the LHS. 1100 KV outrunner, 180 Amp ESC, 2-3S lipos in series.
    Thanks for the help guys.
    Jeff
    Aquacraft Revolt 30, Aquacraft Lucas Oil Cat
    Dumas 44' Coast Guard MLB (undergoing restoration)
    Dumas 55" Wellcraft Scarab 38KV (NIB kit)
  • photohoward1
    • 1610
    Stay away from the Outrunners. They are powerful and cheap but there is not a good way to cool them. For scale look at the Leopard Motors. Go for a larger one. You are going to need 8s to power that beast. Swordfish makes some great 200 amp controllers now. Offshore has all the gear you need.
    • Timmy
      • May 2013
      • 73
      What about outrunners with internal water cooling?
      "Speeds just a matter of money, how fast do you wanna go?"
      • photohoward1
        • 1610
        Post an example.
        • h2o 1
          • Sep 2011
          • 770
          Not cheap by any means but you get what you pay for! Scorpion outrunners rock! Watercooled and i've seen these in several sizes and different kv's of Scorpion outrunners.
          • madmikepags
            • Aug 2012
            • 1359
            castle 2028
            We call ourselves the "Q"
            • Timmy
              • May 2013
              • 73
              ADS400L 3700kv 600w
              • iridebikes247
                • Dec 2011
                • 1449
                MHz and scorpion together make water cooled outrunners.
                • iridebikes247
                  • Dec 2011
                  • 1449
                  2028 8s with a swordfish 240 will be good.
                  • gb tiggycat
                    • 70
                    Out runners are quite easy to mount and cool.
                    [ATTACH=CONFIG]106918[/ATTACHS]
                    • Timmy
                      • May 2013
                      • 73
                      There is the other option of course. Those mounts are good too.
                      • Southwest
                        • Sep 2012
                        • 274
                        3700-400 watt ADS is for 26" boats. I have one and max is 26".
                        • kievyu
                          • Jun 2011
                          • 23
                          twin 3740size kv1180 outrunner ,twin 180a or 120a ESC, 6s2p lipo, x450/3 L&R
                          • Timmy
                            • May 2013
                            • 73
                            I know, I'm just about to put one in a r2 26" deep v. I was just asked to provide an example of an outrunner with internal cooling . In his case he would need to go bigger. Ps. How well does yours go?
                            • Southwest
                              • Sep 2012
                              • 274
                              Not impressed at all!!!! Better off in a 22" light mono with a single lipo. Motor stem is to small and found out the stem will break off if asked to power a big prop. My 26 mono is to heavy as I beefed up the floor as it flexed to much. Most boats are on the thin side unless you strengthen the floor. I do think if you build a wooden mono on a shallow V would do ok but a deep V ? My 26 mono is a Arpro 1. I just took everything out and put a 3S Kershaw motor in with a Octura 438 prop with a single 4000 3S lipo for the h*** of it, just to see how it will do. Bench testing proved I was correct and CG is 30%.
