Bondo for Hulls
  • Phoebe
    • Jul 2013
    • 43
    Bondo for Hulls
    What do you use for patching and filling blems in fiberglass hulls?
  • Doug Smock
    Moderator
    • 5264
    I've had good results with this. http://www.autozone.com/autozone/acc...er=167010_0_0_
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • gsbuickman
      • Jul 2011
      • 1292
      I won't use anything from bondo. I am fond of evercoat's products, primarily 'Rage' . It's so much better than bondo. Its lighter, sands faster & feathers better ....
      • Phoebe
        • Jul 2013
        • 43
        Thanks. Any other ideas appreciated!
        • JLShip
          • Jul 2013
          • 74
          3M Acryl-White glazing putty
          Pin holes fills and can be sanded and painted
          RC Grandpa
          NAMBA Dist. 9
          Folsom R/C Modeleers
          • agentorange
            • May 2013
            • 238
            I use a lot of 3M products also.
            • Islandpride10
              • May 2013
              • 4
              Evercoat rage the best thing out there
              • Heaving Earth
                Banned
                • Jun 2012
                • 1877
                Try to go with a finishing glaze. Pretty much any brand will do. The difference is finishing glaze is designed for light skimming and not for building up, so it is very smooth and leaves no pinholes. If you need heavy build then you need a new hull. That said, go to an automotive paint supplier and grab finishing glaze of any manufacturer ( they will have quality products ) and go for it.
                • gsbuickman
                  • Jul 2011
                  • 1292
                  What kind of blems', or how big of an area are you talking about Phoebe ?. Then we can help tou better. :-)
                  • Phoebe
                    • Jul 2013
                    • 43
                    Originally posted by gsbuickman
                    What kind of blems', or how big of an area are you talking about Phoebe ?. Then we can help tou betted :-P
                    It's just a scuff at the bow, maybe 2" X 1/4". There's hardly any depth to it.
                    Many thanks!
                    • BHChieftain
                      Fast Electric Addict
                      • 1964
                      I use marine epoxy putty-- super strong and perfect consistency. See this thread, towards the end-- my son ran his Miss G up on some rocks and shredded the sponsons and I needed something that would both repair and also blueprint. I found it at West Systems.
                      http://forums.offshoreelectrics.com/...t-modification
                      Chief
                      • JLShip
                        • Jul 2013
                        • 74
                        If it's not taking on water and the scuff is not really deep you might want to wait until you get all the bugs out.
                        Fill and sand and then repaint as necessary. Good luck
                        RC Grandpa
                        NAMBA Dist. 9
                        • tlandauer
                          • 5660
                          Chief
                          Hi Chief,
                          Is this what you used? It's the only Putty I can find in their line.
