Pursuit testing with a 4074 1800kv 180a ecs x447/3 on 6s ?
  • jkr
    FE Addiction
    • 568
    The pursuit i setup is 4s also.
    The rest via mail.
    Also the Tenshock is 3500w ....not 2600w and it is quality motor.
    • lenny
      • Sep 2010
      • 4294
      These boats just need some wings and they can fly away,
      I like the sun setting runs and tunes to add to the fun.
      The rest via mail.
      ? ONLY IF THEY WORK
      • T3tsaya
        • Jun 2013
        • 77
        Originally posted by lenny
        Hi,
        How wide is that river cat32 ?
        The fightercat river 32 inch boat is 9 inches wide
        • lenny
          • Sep 2010
          • 4294
          That just a 1/2" wider than my Daytona,
          And with that hull you need to watch how you prop it because on torque roll from the prop.
          I just us a x442 on mine or a m445,
          But I should try a 3 blade.
          Because they help a lot with V hull torque problem on the V hull boats I have modded so far.
          ? ONLY IF THEY WORK
          • greenblast
            • 292
            my set up is a 40/82 1600 kv.maybe my earlier statement was a little premature. i am just a little excited at the fact i am running a 442 in the high 40's with nothing getting up to 90 deg.
            • lenny
              • Sep 2010
              • 4294
              Well I ran 6s1p today with a x440/3 and gps speed was 48mph,
              And temps were lower than on 4s1p.
              I wanted to try the x447/3 but it got modded today by a big painted turtle,
              It looks like he was trying to add a little more cupping to it.
              He was about 18"long by 12" wide.
              I was running at 36mph with gps on board when the transom came out of the water and it kick the rudder up.
              That was lucky because I had the bolts pretty tight to,
              I just need to give the prop some tlc to get it back in shape.
              ? ONLY IF THEY WORK
              • TheShaughnessy
                • 1431
                That prop might be done Lenny. But see what you can do.
                • kevinpratt823
                  • Aug 2012
                  • 1361
                  I get 55 mph with 1600kx/4082 on 6s1p and a M445 in my Cyberstorm. M445 may be a good step up from the 440/3.
                  My private off road rc track
                  • kwiktsi
                    • Sep 2008
                    • 578
                    Hmm, 55mph with the m445 on that setup, nice! Now I'm curious how fast my Daytona is with the same setup on the X642! I know 8S with the 642 was ballistic! I need to get another small GPS, my damn Note 2 is too big to stuff in the boats lol.
                    My favorite search engine http://google.com
                    • jkr
                      FE Addiction
                      • 568
                      A good choice is prather 225-230.
                      I prefer them over octura on some cases.
                      • lsone
                        • Aug 2008
                        • 48
                        Im watching this thread getting pretty pumped to finish mine. It started as a nitro deal. Now has a neu 1521 1y in it. prop will be a 447/ 3 blade on 6s.
                        • kwiktsi
                          • Sep 2008
                          • 578
                          #27
                          457?????? Yeah, gonna be a bit much for that hull, unless you like barrel rolls :D.
                          • lsone
                            • Aug 2008
                            • 48
                            #28
                            447 3 blade, made an error
                            • kevinpratt823
                              • Aug 2012
                              • 1361
                              #29
                              Mine is actually a neu 1521 1y, so 1577 kv. A 642 was under 50 mph in same setup.
                              Sent from my SCH-I535 using Tapatalk 2
                              • kwiktsi
                                • Sep 2008
                                • 578
                                #30
                                Strange. You'd think the more pitch would have helped MPH, not hurt it. Maybe too much lift? My Daytona really seems to like the 642 over the x445.
