NeverWet for ESC's?
Tags: None
Just perved at the MSDS, looks like a silicone spray on top of a polypropylene base coat.
Interestingly: "Not intended to be applied to electronic devices or clothing".
'Not intended' means it should be tested yes?
Wisdom is knowing how little we knowComment
I posted this earlier but more geared toward the bottom of hulls. I'm sure this would work well for ESCs, Rx and servos.
I'd try but mine are already waterproof.
Sent from my DROID RAZRComment
I let the dogs out...Comment
I still don't understand why people think a rough surface is more hydrodynamic. But I originally purchased this by the parent company and it depends what your uses are. When properly applied it has the feeling tacky felt. Water does need up and run right off but it is a dust and dirt magnet. Can be scratched very easily. Comes off with many solvents, naphtha,xylene , acetone ect. I sprayed a hull and ran once then wiped the whole bottom off with xylene. Left it on to to help repel water but it has very little left after a couple months of handeling. But it is good stuff just not as durable and speed oriented as we would require for our hobby. Now that the price is way down from $200 for a quart (top n bottom coat) get some and try out, Im positive anyone can find many uses :)Comment
a rough surface works better. look at a golf ball, its designed with the dimples to make it fly farther, straighter and even correct slice and shank. dimples do work better for some reason beyond me. more so look at a sharks skin, quite rough, yet very efficient at slicing through the water.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/Comment
Oh boy here we go again , lol,,, yes on the golf ball but the reason is wrong. The dimples were established on a golf ball because they were hit dead, no rotation. On a dead ball the dimples will create I consistencies in the airfoil allowing greater flight distance and accuracy.a rough surface works better. look at a golf ball, its designed with the dimples to make it fly farther, straighter and even correct slice and shank. dimples do work better for some reason beyond me. more so look at a sharks skin, quite rough, yet very efficient at slicing through the water.
Sharkskin, completely different, fish have scales, sharks have skin. Like mole hair on cross country skis - directionally smooth as opposite rough. And very seldome addressed in fish is the mucus membrane (slime) that effectively negates dragg (from scales or skin) dolphins are similarComment
And this is the only place I know of that the racing world believes rough surface is faster. World class race boats and world economic shipping companies invest a lot of money to make their vessels more slipstream. (Paint, coatings, shape ect. )Comment
golf balls get quite a bit of rotation, so idk how you say thats why they have dimples. and a sharks skin is far from smooth, only feels smooth to the touch in one direction, look at it under a microscope and you will see. http://entertainment.howstuffworks.c...question37.htm here's the explanation on the golf ball. large ships want smooth because they have no real separation from the water surface like a planing hull. the rough surface would allow for tiny microbubbles under the hull which is less drag on the hull then smooth water.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
Who gives a crap what golf balls do? They're moving thru the air, not across the water. Two completely different elements.Comment
actually very similar, its all a part of fluid dynamics.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
