Removing Prop Nut
  • SloHD
    Slow Electric Addict!
    • Apr 2013
    • 337
    Removing Prop Nut
    So how are you guys removing your prop nuts with the flex still installed in the boat? Basically how are you holding back on the shaft/prop without damaging anything? Having trouble wrapping my head around this, without damaging anything in the process. Thanks for any help.
  • Rumdog
    • 6453
    Grab the prop with a rag in your hand and unscrew the nut,
    • Alexgar
      • Aug 2009
      • 3534
      I use a leather work glove but same as above and invest in a cheap nut driver
      • SloHD
        • Apr 2013
        • 337
        I've tried that and it has worked a few times. But runs the risk of bending the prop.
        • Rumdog
          • 6453
          If that's true, your nut is waaaay too tight!
            I suppose you could grab the drive dog with vice grips, but I too prefer to hold the prop. What are you using for prop nuts? These are (IMO) the best: http://www.offshoreelectrics.com/pro...?prod=ose-8135
            • SloHD
              • Apr 2013
              • 337
              Ok, I figured you need it nice and snug because I am getting the prop coming a little bit loose after about 5 runs or so. Almost like the drive dog moves, or the nut is backing off ever so slightly. Maybe I want this slight movement in the prop? Btw we're talking about normal proboat hardware here. 3/16 shaft, x642, Mystic 29...
              • SloHD
                • Apr 2013
                • 337
                I'm using those same type, except the one's that kintec sells. Next time I make an order on ose I do plan on ordering some of those tho.
                • TheShaughnessy
                  • 1431
                  I agree. Or your prop may be a bit too thin. I always just grab the prop with a paper towel or my shirt or something . Dab of blue loc tite maybe
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    Not wanting to jack this thread but a couple weeks ago I received a pack of those that fluid posted a link to.
                    All 3 are loose to screw on. Can you put them in a vice or some thing and give them a little squash ?
                    • lenny
                      • Sep 2010
                      • 4294
                      When you screw it on is their any thread left showing at the end of the prop nut ?
                      ? ONLY IF THEY WORK
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        Not sure if this was directed at me ?
                        If so you can screw the nut down to the prop by hand and still have 1/4" of thread showing
                        • Alexgar
                          • Aug 2009
                          • 3534
                          Tiny dab of picture may help
                          • lenny
                            • Sep 2010
                            • 4294
                            Than just put a piece if fuel line or water line on the 1/4 thread.
                            I have just used fuel line with no nut to hold props on when doing lots of prop testing,
                            And it holds them on good.
                            I never lost a prop from doing that ether.
                            ? ONLY IF THEY WORK
                            • lenny
                              • Sep 2010
                              • 4294
                              What is that ?
                              Something like thread locker blue.
                              ? ONLY IF THEY WORK
