What Prop To Run Delta Force 33
  • madmikepags
    • Aug 2012
    • 1359
    are they new batteries? is the boat running wet? With the same exact setup I can pull a 648 with cup on good 4s 5000's 1P and get the batts around 140, with 6600 mah you should run cooler especially with a 445 theres something not perfect there. Hyperion 35C are as good as most other companies 50-60C rated batteries unless they are old? also I don't like cells smaller than 4000's in boats, I just feel the smaller cells heat up no matter what, I feel the lager cell dissipates heat better, I have no proof just my feeling. 85% of my boat batteries are 5000's and up the rest are 4000-4500
    We call ourselves the "Q"
    • SSchevy98
      • Sep 2012
      • 90
      What props would you recommend this setup?
      Motor : Lehner 2250 1315 kv.
      Esc: MGM 250 A 8s .
      Batterys : Thunderpower 4s 6600 mah 70 C
      Connected in series.
      Deltaforce 33" cyberstorm 8s Lehner 2250/9 1315 kv/ Leopard 4082 1250 kv .
      • madmikepags
        • Aug 2012
        • 1359
        according to what you say you will be running 8S? is that correct? what is the # on the motor 8-9-10??? you're talking close to 40K rpm and a 2pole motor compared to NEU's that are 4 pole. that motor is much more suited to 6 cell, on 6 cell i would use a 445-447 maybe try a 440 on 8cell?
        • SSchevy98
          • Sep 2012
          • 90
          Hi madmikepags,
          Yes i running 8s , lehner is 2250/9.
          I can try these propellers x440 / 3 prop, m445/2, x450/3 and x452/3 ?
          Few picture my deltaforce 33 :D
          Is the boat painting fine do you think?
          • ray schrauwen
            • 9475
            Are those the carbon Chinese turn fins?? I have a set and want to use them on my DF33.....
            Originally posted by mojoracer
            I have a P-mono class DF 33 with a NEU1515 1Y on 4S. Any suggestions for props with this set-up?
            Nortavlag Bulc
            • SSchevy98
              • Sep 2012
              • 90
              Yes i running 8s , lehner is 2250/9 1315 kv motor.
              • ray schrauwen
                • 9475
                What speedo do you run in that Bob?
                Nortavlag Bulc
                • jasburrito
                  • May 2013
                  • 3
                  #23
                  skip those props and get a cnc from ose. They make the octuras and such look silly. I ran x445 for a bit with mm modded, medusa research 36/70 2300 3s to 6s (holy amp draw). http://www.offshoreelectrics.com/pro...od=cnc-4214250
                  way nice.
                  • SSchevy98
                    • Sep 2012
                    • 90
                    #24
                    Hey all,
                    How much of your deltaforce 33 boats weigh in running water ?
                    My boat weighs 4600 grams in running water .
                    • ray schrauwen
                      • 9475
                      #25
                      I will try to weigh it for you tomorrow. With Aquacraft motor +120amp esc or 4092-2200kv fightercat+ SF200 esc?
                      Nortavlag Bulc
                      • SSchevy98
                        • Sep 2012
                        • 90
                        #26
                        Hi Ray,
                        Is it too much ?
                        Setup: hifei swordfish 300 a pro plus esc , lehner 2250/9 1315 kv motor + x2 4s 6600 mah 70 C lipo batteries in series.
                        Props: x446/3,x450/3 or x452/3 ? Are those too big or not?
                        • madmikepags
                          • Aug 2012
                          • 1359
                          #27
                          jasburrito, the cnc props are nice but an experienced racer really has no use for them, there really is no tuning them to specific boats and conditions, I have well ove 200 props and I can say there is not one of them thats stock.
                          • mojoracer
                            • Sep 2010
                            • 613
                            #28
                            The fins came from OSE Ray....
                            Bob Zola NAMBA 212
                            2022 NAMBA Nationals FE High Points Champion
                            Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
                            • mojoracer
                              • Sep 2010
                              • 613
                              #29
                              I run a ICE240 Castle
                              Bob Zola NAMBA 212
