I continue getting questions about the drive wire system and the stock .047 just is not a good enough setup for this boat.
I am playing with a new set up with a 062 wire and stub and drivedog and bullet nut. You can use your own stock coupler after you drill it for 062... which is very simple. I would run a x432 or even slightly larger Octura prop and it should run out very well. You will also have to drill out the stuffing tube plug to fit the new wire...very simple.
The boat looks like a blast.
Any other input on this rig?
