Have you tried a propane torch? You need to be careful but back in the day many folks used one to remove paint from wood. Apply heat to soften the paint then scrape it off.
Paint removal
Lol. No. I did that by spraying a lot paint to the point where it builds up. If you wait 2 min and scrape of that area layers of old paint come off as well. It's just sucks that I'm waisting paint to take paint off2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
Soda blasting will do the job. Its a bit like sandblasting but there is way more control . You could have just the topcoat blasted off if you wanted to, leaving the original primer intact.... ready to repaint, Or have the lot removed ready for fresh primer and paint. Gets at those hard to sand areas no problem!!Im confused..... no...wait...mabee im not?Comment
Aircraft stripper will eat thru urethane clearcoat unlike standard furniture grade stripper. From what I can tell proboat uses the urethane type 2 part clearComment
Removal
Wet sanding. Using different grit sand paper. And little by little it's coming offAttached Files2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
everywhere I used the citrus stripper the paint has softened so now I have to get it off. Goign to liook for some stripper that is ok to use on fiberglass"Our society strives to avoid any possibility of offending anyone except God.
Billy GrahamComment
In car restoration removing paint from small plastic brittle parts I soak them in brake fluid works well on fiberglass as well easy clean up easer than stripper and cheaperTop Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPHComment
First water than ISP alcohol cleans up really niceTop Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPHComment
