Paint removal
  • Hor2012
    • Jun 2012
    • 348
    Paint removal
    I need help!! What's the best way to remove layers of paint on a fiberglass hull. I want to get down to the white gel coat finish so I can paint it again. Anything will help
    2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHome
  • JimClark
    • 5907
    Trying to remove the paint from a mystic 29 right now tried two of the Safer type paint strippers and so far they are not touching it much. Might just have to go to the really caustic stuff to get the job done. Bear in mind if you remove the paint chances are that the gelcoat had to be roughed up for the paint to stick well
    Billy Graham
    • Hor2012
      • Jun 2012
      • 348
      I painted it trough out the years and now I want to go back to white gel coat but there is 3 layers of paint under it and I'm not sure if using chemicals to do it will soften up the gel coat
      • Basstronics
        • Jun 2008
        • 2345
        http://www.wmbarr.com/citristrip/default.aspx
        Removes any paint Ive laid down. Safe too.
        • JimClark
          • 5907
          Don't know what probaot uses for paint but know for sure it is thick and citristrip isn't touching it
          Billy Graham
          • Basstronics
            • Jun 2008
            • 2345
            Is it paint or gel coat you are trying to remove?
            Wheres Mr Jordan?
            • JimClark
              • 5907
              Paint
              Billy Graham
              • Basstronics
                • Jun 2008
                • 2345
                The stuff I linked to has easily removed Krylon, Testors Enamels, Rustoleum. I have used it on some unknown paints to and its worked awesome every time.
                • Peter A
                  • Sep 2012
                  • 1488
                  If all else fails,... sandpaper and elbow grease!!Lol.
                  • JimClark
                    • 5907
                    I will send it to you to do that or just drive my car over it and put this boat out of it's misery wish Id never have bought it now
                    Billy Graham
                    • Basstronics
                      • Jun 2008
                      • 2345
                      If the paints on there that good does it really need to come off? Couldnt you just scuff it up and spray right over it?
                      • JimClark
                        • 5907
                        Too many times have I seen reactions when doing that
                        Billy Graham
                        • Hor2012
                          • Jun 2012
                          • 348
                          In my case. I wanted a fresh look for this year I sanded it a little did primer and painted after about 20 min the paint started cracking and coming off. Not sure what the issue was but paint won't stick no matter how many times I sand and paint. So I figured to take all paint of and start from the base.
                          • iamandrew
                            • 577
                            I would have just sanded it off instead of trying to use solvents, i found that they permanently weaken the outer layers of gelcoat and fibre glass
                            • Hor2012
                              • Jun 2012
                              • 348
                              That's what I'm afraid of doing. There is just some areas of the hull where it will be hard to use sandpaper
