I use an Octura x-442 de-tongued and cupped just a bit.
Favorite P-Mono motor??
You are right in your thinking Ray.
Generally, most motors with the wires coming out the sides of the can have shorter windings & a shorter armature compared to a motor of the same can length with the wires coming out the back.See the danger. THEN DO IT ANYWAY!!!
Well, when I tear down my P-mono for winter Maint. I'll know what condition my 4092 TP Power (via FC racing) is in. Hopefully the rotor, bearings and stator are all in top notch shape.
I am thinking a 1515 Castle possibly if the TP bites it.Nortavlag Bulc
The D-12 boys are right on with a 1515/1Y and 1521/1.5D. I ran the 1515 in a couple races and did well with it on my DF33. Since we have cut a half second or better per lap going to a TP 4092/2200kv. I do feel the 1521 1.5d might be better yet and I have one in the box.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414Comment
What prop works on your DF33 with TP4092-2200? Thats the motor I have. 42mm?
MicNortavlag Bulc
I run the 1515 1Y 2200KV on my 29" syncron. It runs cool on 4S1P up to an x442 prop (my standard prop is 440), and I seem to get more run time vs. a similar size/kv leopard. Likely a more efficient motor, but since we run different brand packs I can't be sure... my config is hyperion packs + neu motor vs turnigy packs +leopard motor.
Chief
Are both hulls running the same props?I let the dogs out...Comment
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414Comment
The 1521/1.5d is my motor of choice, I can prop it w a prather 235 to 245 or X450-455 depending on conditions, I run a DF cyberstorm w 4S2P Dinogy batts. Current P-mono National champion.We call ourselves the "Q"Comment
ChiefComment
