How to cut a Prop
  • chisoxguy13
    • Mar 2008
    • 43
    How to cut a Prop
    Does anyone know where I can find some info on how to cut a prop including detongueing? Thanks
  • Chop
    • Nov 2007
    • 504
    Someone sent me to this site when I asked the same question...
    There is a fine line between "hobby" and "mental illness."
    • Dr. Jet
      • Sep 2007
      • 1707
      Here is how I have done de-tonguing in the past:
      Chuck an old propshaft with drive dog into a drill press or lathe in such a way that a file or belt sander can reach the prop tongues when the machine is turning. Install the prop onto the shaft and turn on the machine. When spinning, an "X" series prop makes a sort of "M" shape. Using a coarse file or small belt sander (a dyna-file is perfect here), carefully grind away at the tongues while the prop is spinning until the spinning prop shape looks like a parabola.
      Remove the prop, and you will see that the freshly cut leading edge is quite thick. File, then sand the drive-dog side of the prop until it is thin, smooth, and without "lumps".
      • ReddyWatts
        • 1700
        This thread has info about the difference in X, Y and M props.
        http://forums.offshoreelectrics.com/...light=x+m+prop
        ReddyWatts fleet photo
        • chisoxguy13
          • Mar 2008
          • 43
          Thanks for all the help. I'm going to try and cut some tongue off tomorrow.
          • chisoxguy13
            • Mar 2008
            • 43
            Also Found this which has alot of info that anyone might need.
