I was only able to find down to 10-24. Why not just use a fender washer/ nut and eliminate the t-nuts?
Anyone ever seen Stainless steel blindnuts?
I'm with Jim in preferring stainless blind nuts. The non-stainless ones, once there's any water intrusion on the threads ( and face it, water will eventually get inside) will corrode and corrosion-bind the bolt to the blind nut. Once this occurs, backing out the bolt often spins the blind nut and it becomes asituation (ask me how I know
) I don't like using blind nuts for transom hardware; prefer stainless bolts and nyloc nuts. Where blind nuts are called for, the stainless ones at my LHS don't have the points so I use tiny screws to guarantee that they don't rotate. Slightly more labor intensive, but less of a hassle than dealing with a barbed blind nut that's locked on to the bolt and rotates with it.
Couldn't find a stainless one for the picture, but here's what I'm talking about :
Jim, I can see if my LHS has what you're looking for if you need me to. Often they only have stainless non-barbed in metric but there should be a close metric equivalent to 10-32 ; I've gone that route in the past.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Transom plate of 1/4 alu, mount, then drill and tap to suit.
Nuts, what nuts ?
W
I am reworking a mystic 29. The ones on the wooden backing plate at the transom were rusty and the wood was falling apart so I am replacing all this and reinforcing the transom. If I can't find SS then I will have to use the zinc coated ones or I may make a backing plate out of 1/8 alum and glue that in and just thrubolt the strut bracket
Sent from my MB611 using Tapatalk 2Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
