Upgrading the Zonda Cat with new Motors
i think about 2000-2200 kv because its a twindrive and one motor helps the other, i will pull less amps then a singledrive, 5s lipos (18,5v) for a 20v motor is ok i think, 200 amps plus ish x2 will carry that all, going for 45mm to 48mm props (checking temps first with 45mm) i dont want 10 minutes drivetime, i just want to see whats the max speed on this hull with this setup with a 40mm motor :)Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
cant, i woud but i cant get rid of them, the whole boat is build squaredrived ;( everything filled with epoxy, stinger brass tube, brasstube holderhere you can see the boat, jan from kintec sells it to: http://kintecracing.com/Zonda_Cat.html
The place that sells the Zonda cat sells 4 pole 4074 2200kv motors with coolers for about $60 each I think.....
Just in case you haven't looked... at HOR that is.....Nortavlag Bulc
i know, but the brand..... i like leopard motors, sss is not my favorit, tp is ok but expensive, but why go for 4074? the money for 2x leo 4082 i got, and i think they are the best choice in the 40mm“sZonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
Up to you man, the 4074 motors on HOR's site will do the job but when you trying to achieve the highest possible top speed, the 4082 motor will spin a larger prop on the same voltage.Comment
Last edited by drwayne; 02-11-2013, 07:53 PM.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
here it is drwayne: http://forums.offshoreelectrics.com/...h-PLUS-200-amp
still cant setup the esc“s, trying already about 4 hours, cant get 100% throttle -.-Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
Figured I would post a link to this video, pretty crazy...
