Upgrading the Zonda Cat with new Motors
  • Mecka1990
    • Aug 2012
    • 175
    Hi guys,
    now i want to upgrade my 41" twincat with new motors, actual motors are the sss 37mm 2075kv 4 Pole d Wind, i want more power
    so, wich motors i shoud put in, there is only room for a 36-40mm motor on each side (36-40mm motor mount), lenght max 95mm. Want to get max speed so i think a D Wind will be the best.
    i only know the leopard motors, but maybe you can help me getting something better?
    4082: http://www.leopardhobby.com/proviewe...=1&gid=68&pt=3
    4092: http://www.leopardhobby.com/proviewe...=1&gid=68&pt=3 btw, i cant find the 2080 Kv/rpm per volt 2.5D on the leopardhobby.com page, i missed something?
    setup: 2x hifei swordfish 200 plus, 2x 5s lipos 50/100c, 2x 45mm cnc props (maybe with the motors bigger props?)
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    D wind are generally better for applications that require movement in both directions vs y wind which move better in one direction, so is a d wind really gonna be any faster?
    Dunno where you got the idea you need a d wind
    • Mecka1990
      • Aug 2012
      • 175
      from the last motor question (spartan) and they said the opposit..... Y for forward and reverse, D for max speed, and D can pull more amps...
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        I could be mistaken, but I could swear I read y wind for one direction
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          Motor wind type comments from the chief engineer at Aveox:
          "At Aveox, we have essentially deemed the Deltas as secondary to Wye winds in any application, except where a very high degree of uniformity in both directions is very important. Things like robots that move in both directions equally put up with the efficiency losses. Since the motors are very insensitive to timing changes (unlike the Wye winds), you don't have great performance in one direction, and poor in another(without adjusting the timing). You have good performance in both. (but it is not worth the losses in a model).
          So basically the Wye will spool up faster and reach its top RPM a bit faster than the Delta wound motor. The Delta wound motor also consumes more amperage than the Wye motor. If you want a hi-torque motor, the Wye-wind will let you do it with few turns. If you want speed, the Delta motor will let you do it without having to use difficult, thick wire or mess with parallel strands."
          Posted by fluid in another thread
          • Mecka1990
            • Aug 2012
            • 175
            so a Y woud be better, but if he said both directions, a d wind woud be better for a cat, because a Y is better for one direction, and i drive both because one is counter rotating... maybe im wrong now..^^
            • Mecka1990
              • Aug 2012
              • 175
              or is it the same when i change one of the 3 wires on the motor.....is it still forward?
              • iridebikes247
                • Dec 2011
                • 1449
                x447 with leopard 4082 2000kv motors....you'll go fast
                Ok this is a setup but really a SAW one the boat will haul. I run a boat the same size with leopard 4082 1600kv twin motors, x447s on 5s usually. The boat runs upper 60s and is still "fun." By that I mean im not swimming after it often, it can take some chop and the power doesn't overwhelm the boat in most situations. That boat is light doesn't need twin 4092s. My boat electronics stay cool and I get very good run time with the 1600kvs.
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
                  I believe which ever direction is set to forward via the esc is gonna be the direction the motor performs its best regardless of which direction that may be. In different applications forward is gonna be different rotation based on what's needed. I'm not 100% sure tho
                  • Mecka1990
                    • Aug 2012
                    • 175
                    so i think the best with 5s lipos will be:
                    Model: LBP4082
                    Max Amps: 140A
                    Max V: 20V
                    Max Power: 3500W
                    Kv: 2200kv
                    ResistancE: 0.006
                    No-load -Current(15V): 3,9A
                    Mounting Hole: 7mm
                    • Heaving Earth
                      Banned
                      • Jun 2012
                      • 1877
                      Twin 4082 might be a bit much. Maybe go for 4074
                      • Heaving Earth
                        Banned
                        • Jun 2012
                        • 1877
                        Regardless, my point is, don't limit yourself to a d wind motor
                        • Mecka1990
                          • Aug 2012
                          • 175
                          what you mean with much? haha
                          i want a saw setup like iridebikes247 said, but scared of overheating. the esc“s shoud not got any problems with the motors and lipos, so only the motors make me scared, i dont think that i will pull more then 110 amps with this build
                          • Mecka1990
                            • Aug 2012
                            • 175
                            i wont, just readet it, its wayne wich direction the motors turns, its still forward, a d wind is better for forward and back, like a car ...
                            • Mecka1990
                              • Aug 2012
                              • 175
                              im still searching for a 1/4 flexcable with 3/16 squaredrive end, i dont like the teflon drive whats in it, it makes me sick, every month changing the teflon liner, and its not easy if you only got 20mm room to fit the new in it
